![]() | Home > Technical (L322) > Strange Noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
i would have said the FBH, but you say it comes on when hot , so ?... ... - .- -.
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
a thought, could it be the cd changer in the glove box, maybe the disc is vibrating causing the humming... ... - .- -.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Frightened passenger? |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Or a very horny field mouse getting it on with the warm ECU. Tom
The passenger seat often does moan, but much louder and more focused. ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
fuel pump running? There is nothing that can't be fixed with a hammer😜😜
Some good thoughts so far..... will have poke around tomorrow......
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
Its unrelated - but I had an irritating rattle in the cabin that I was positive was coming from the passenger side. When SWMBO was in the passenger seat she swore it was coming from the drivers side. It turned out to be sunglasses rattling in the overhead holder (middle) - easy fix!!
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Sure there is a post somewhere which references a noise relating to the parking sensors, my 07 does it sometimes, more prevalent after heavy rainfall. It usually lasts a very short period of time and is very intermittent, therefore it remains un-diagnosed in my case. First time I heard it, it was a very peculiar noise which didn't sound like normal engine /suspension noise issues I'd encountered in the past with other cars.
Thelord67 Member Since: 19 May 2012 Location: Stockport Posts: 27 ![]() ![]() ![]() |
I have the exact same noise, always does it on cod start up after engine running for about 1 min, but then re do it later for no apparent reason! I stopped once and popped the bonnet and was very loud and seem to one from the air box, still haven't diagnosed the problem Range rover tdv8 56. Vogue
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Whooshy oil pump? |
Had a good hunt around, and not necessarily any further on, but am trying things in order.... Problem with intermittent faults... No idea if fixed or not.
