Home > Maintenance & Mods (L322) > What Price to get a FBH repaired |
Have to get this into the dealers to get sorted , anyone know a price thats had it done , press the remote and you hear it kicking in but it only lasts for about 30 / 40 seconds then nowt
1st Dec 2012 11:20am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Mine broke. It was apparently unrepairable, a new one was ฃ1400 ... Warranty Direct paid because the fault was (it seems) in the internal ECU , which they DO cover. The FBH itself wasn't covered.
1st Dec 2012 11:25am |
Cheaper to clear out the garage Mick |
1st Dec 2012 11:28am |
@ Graham
1st Dec 2012 11:32am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3166 |
Just tried mine this morning for the first time (2004 4.4V8 petrol) and everything worked: on pressing the remote, lights flashed red, fan started up and ran for c.17 minutes, but no heat!! Does this mean the glow plug is kaput or is there another cause?(sorry Joker, not trying to hijack your thread, but are your symptoms similar?) |
2nd Dec 2012 12:15am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8619 |
2nd Dec 2012 7:15am |
Well went out to the car this afternoon fired the FF up let it run for about 10 mins switched it off , then pressed the remote for the FBH and hey presto it started but after about 17 mins or so inside the car was still cold and the outside windows still frosted up all that had changed during the 17 mins it was on was this , as you can see certain bits on the bonnet started to thaw out
2nd Dec 2012 6:53pm |
This was mine this afternoon
2nd Dec 2012 6:59pm |
So did you lift the tiles off the floor to put the car in to take a picture ====================================
2nd Dec 2012 7:09pm |
From that it looks like the fbh fired bt was circulating the coolant round the block not the heater matrix, could be the solenoid valve which diverts the flow to the matrix. Cheaper than an entire unit. However a pig to get at.
2nd Dec 2012 7:33pm |
Tiles are gone again Mick...HP repo'd |
2nd Dec 2012 8:04pm |
