Home > Maintenance & Mods (L322) > Brake squeal |
Buy a new set of pads from Dan at Duckworths |
29th Nov 2012 9:20am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
could be the actual pads, my wife had the same problem, changed the pads to another make and all was well.. ... - .- -.
29th Nov 2012 9:21am |
Would you like to rephrase that Stan |
29th Nov 2012 9:24am |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 |
Thanks chaps.
29th Nov 2012 9:34am |
Send Dan a PM or call him |
29th Nov 2012 9:41am |
Ta, will do. |
29th Nov 2012 9:42am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I had he same problem with mine, even the extra rubbing noise when turning. Replaced the caliper and all was good. Maybe your caliper has started to stick a bit????? I got a new one off the bay for £45 so might be worth a try. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
29th Nov 2012 2:23pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Another vote for the pads. Some pads and disc combos just squeal with the type of braking the driver does. I used to get squeal from the rears a lot ... i figured it was cause I did a lot of long gentle braking with the horse trailer attached.
29th Nov 2012 3:36pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
You can never use enough copper grease. Slap it all over, well, the back of the pads I mean. It's defo the front? What happens if you put the handbrake on a bit, does the noise go? Previously..
29th Nov 2012 3:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
When I just did my rear pads one was starting to squeak a bit, picked up some copper grease and the chappie in ECP said that PAGID now did their own non metallic compound which was better at stopping squeal. only cost a couple of squids for a small tube and seems to have done the trick, along with the new pads that is. There is nothing that can't be fixed with a hammer😜😜
29th Nov 2012 4:49pm |
