Home > Technical (L322) > STEERING FROM HELL !!!
R4NCE
2002 Range Rover Vogue Td6 Zambezi Silver
Morning All,
Okay here goes, Range Rover TD6 2002. Steering Very Heavy all the time.
Firstly, checked the pump but its okay. Changed servotronic valve and checked voltage going to it (10.9v) still the same.
Changed the PS Fluid yet steering still heavy. Have checked for fault codes and only thing that came up was Front n/s ABS sensor which i have now replaced and also the earth strap coming from ABS unit under the bonnet was slack which i tightened. No Faults at all now however still have heavy steering.
When I reset everything through OBD port, it now never says HDC control Inactive for some reason!!
Any help will be appreciated, A desperate man, James
Post #154038 28th Nov 2012 9:22am
fisha
When you reset stuff and disconnect the battery, you need to turn the steering from lock to lock to reset the HDC. There is a steering angle sensor that needs re-calibrated by going from lock to lock.
The front tyre pressure also makes quite a noticeable difference to the weight of the steering.
Lastly, when you say heavy, what are you comparing it to? My RR would feel very heavy compared to my freelander.
Can you hear the pump work the fluid when you turn the wheel. You can normally hear it skiiiiissssshhhh as you turn the wheel. V8 or else ...
Post #154039 28th Nov 2012 9:26am
looks like you've rectified all the possible causes... i can only think is , is the servotronic valve voltage correct [guess] and did you change the little filter when you put the new valve on... ... - .- -.
Post #154040 28th Nov 2012 9:27am
R4NCE
Thanks for the fast replies.
The message HDC INactive does not appear on the screen anymore. Even when battery disconnected!
Servotronic valve was replaced with a new filter as well.
Totally stumped!
Post #154044 28th Nov 2012 9:45am
many years ago on my morris marina the bottom bushes started seizing which resulted in very heavy steering, could this problem apply to the fullfat..
edit, you could rev the engine up and see if that improves the steering then that could be what NDFI [below] suggested.. ... - .- -.
Post #154047 28th Nov 2012 9:54am
Drive belt slipping on power steering pump?
Post #154049 28th Nov 2012 9:56am
R4NCE
No sorry changed tensioner as well Smile
But thanks
Post #154050 28th Nov 2012 10:01am
Prop
You may want to look at the BCU unit under the passenger seat. This dictates when the servotronic steering engages. If it is faulty then the steering could be stuck in high speed mode. I had an intermittent issue where my steering was stiff at startup and normally turning the ignition off and restarting the car corrected it. I recently cleaned all the connections to the BCU and the fault seems to have been fixed.
Post #154059 28th Nov 2012 11:31am
R4NCE
Hi all!
Okay update. Got myself a new servotronic valve and nothing has changed !
So far have changed power steering pump, changed the fluid, new servotronic valve ! Measured the voltage going to servotronic valve when vehicle stationary and its showing 10.9v does anyone know if this is correct!
I just don't know where to turn next ! Anyone got any ideas?
Post #154885 2nd Dec 2012 1:33pm
Have you checked out the BCU yet, as per post above ? .
Post #154890 2nd Dec 2012 2:15pm
R4NCE
hello,
Yes took it out opened it up and it looked brand new however unsure what voltage should be ! Is 10.9v right while the vehicle is stationary
Cheers, James
Post #154896 2nd Dec 2012 3:11pm
James
Have you cleared the faults? When I got mine had increadibly heavy steering. Thought it was normal untill I got my RAC and cleared all the faults. Next time I drove it I almost ripped the steering wheel it had gone so light. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #154902 2nd Dec 2012 4:27pm
R4NCE
Yeah all faults cleared many times . Disconnected the battery over night and still no difference.
How can i get the BCM checked / re programmed ? Only other thing i can think is the rack however I really can't see it.
Cheers, James
Post #155015 3rd Dec 2012 8:33am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I'd start by jacking up both the front wheels and having a very good look at all the steering components - ball joints. track rods, bushes etc., to see if anything is seized up.
Is the steering heavy or light when the car is jacked up - and can you turn the steering from lock to lock just by turning one of the front wheels (when they are off the ground!)? If not, it may be a simple seized joint after all...
Post #155066 3rd Dec 2012 11:24am
ebajema
Have you looked at the steering column itself yet ?? May be worth a look as well because it sounds like a major seizing up of the steering components to not allow the power steering to make it light. MY 2010 5.0 SC Galway green and sand interior!!
Post #155069 3rd Dec 2012 11:43am
