![]() | Home > Technical (L322) > no heater blower |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
just been out to pick shmbo from work and noticed the heater blower wasnt working .lights around knob light uo also the ones on the knob light ,the light in the temp switch are dim,if i set the face level demist and foot well buttons to on and drive at about 50 mph can feel heat through the vents.
Classic FSR .
just as i thought blower not working iwith switch turned to any position,fsr have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
I'd also check the following fuses, you might be lucky,
well just been out to have a look at fueses ect still no joy then all of a sudden a click and hey presto the |
well fitted new fsr a week ago all fine for a week now doing the same again, workes sometimes then wont .
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Mine has been working fine and at random times just going off. A press of auto brings it all back to life. Is this the start of FSR failure or am I doomed? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Doomed |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Not to worry anyone but I had motor problems and turned out to be the blower motor, not too worry Autodata gives 14 hours and the part is around £400, I had mine changed last week and put a new FSR in (3rd one) just to be sure. One day your life will flash before your eyes......................................make sure yours is worth watching!
14 hours......
Took around a day to do and used a 2nd hand motor, no labour so not too bad at all. One day your life will flash before your eyes......................................make sure yours is worth watching!
dont mind doing it my self but looking on rave looks like you have to have ac disgharged or it there a easyer way ???
I didnt do it, got one of the lads to do it, any decent garage can degas and regas your AC system. One day your life will flash before your eyes......................................make sure yours is worth watching!
just done a temp fix ,motor was turning but very slowley and stopping so wd40 and switch cleaner sprayed into holes and a big stick and now working. know will have to strip the dash and every thing later but if i can get away with doing this till the wether gets better lol i will be happy and warm .
