Home > In Car Electronics (L322) > Range Rovers with DSP, that have lost sound |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
BARIS, you come as an angel to me, from 7 months driving without sound, and I've tried everything, the radio module work as well, and I believe the problem was the dsp lear from the first time.
20th Nov 2012 7:51pm |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 |
First things first. There are a few tests you can do.
21st Nov 2012 10:29am |
Baris, I checked the output voltage (pin 13 bm54 to pin 8 DSP) and seems to be ok (12.7v) the radio module work correctly, also because I have no audio from either nav.
25th Nov 2012 7:00pm |
26th Nov 2012 1:58pm |
Better off without DSP anyway sounds awful.... |
26th Nov 2012 2:18pm |
Thank you Baris , I will check now, bm54 speaker output, can I connect spare speaker into dsp connector?because I can't get the radio connector . alternatively can be fit Harman Kardon logic 7? |
27th Nov 2012 1:00pm |
I tried to see if spare speaker can work connected to pin 4- 9+ and/ 5- 10+ on the DSP conector (X18773/26) but no result, AND no audio. I tried with dsp not connected),. I noticed that the radio time during the search does not find anything. in this case can be the radio module the problem.. I would know because just yesterday I took a dsp on ebay, and I would not be useless |
27th Nov 2012 4:55pm |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 |
I appear to have lost some of the channels, the sound is full of base and muffled, any chance of this being fixed by you baris?
25th Jan 2013 5:46pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Check the plugs that go in to the amp, the pins are most likely corroded due to water ingress or the amp circuitry is damaged |
25th Jan 2013 8:30pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1703 |
Hi Steve,
27th Jan 2013 8:25am |
Andrew, if you have no speaker output from the bm54 it very well must be the bm54. What do you mean by, you can't find radio stations? Can you search for radio and flick through the modes?
28th Feb 2013 11:13am |
Update Baris
1st Mar 2013 7:48pm |
Turn the DSP off - sounds better |
1st Mar 2013 7:52pm |
I wonder if that will confirm the issue though. If i just turn off the DSP (via the screen options) and see if the radio/sound cuts out again. If not then it's deffo the DSP AMP that's goosed..? Ash
1st Mar 2013 7:54pm |
