Home > In Car Electronics (L322) > Range Rovers with DSP, that have lost sound
Baris
I am referring to the ibus RRs. which have the extra LEAR amp in the boot.
It has come to my attention, that when the battery dies, these amps stop working. I have received a lot of phone calls, where sound has stopped working completely, but the bm54 still working.
The first assumption is the BM54 at fault.
At first I didnt believe it was the BM54 unit, as when I received them, they worked as normal. After finally, getting my hands on a RR, I was able to find the cause. I think!
I will know for sure, once I have tested and repaired more BM54 units. It should be a lot more straight forward, now that I know what to look for.
I want to save people from having to try and source one of these rare LEAR amps!
Post #152218 20th Nov 2012 9:54am
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
BARIS, you come as an angel to me, from 7 months driving without sound, Big Cry and I've tried everything, the radio module work as well, and I believe the problem was the dsp lear from the first time.
many people told me that the problem was the bm54,(also reading here) but I've always had and belief that my amp blew up.
Now, you confirm my hypothesis, so I hope I can solve.
think I have to change amplifier?thanks
Post #152374 20th Nov 2012 7:51pm
Baris
First things first. There are a few tests you can do.
1. Use a multimeter to measure the voltage coming out of pin 13 of the bm54 connection. If its not 12v, then the Lear amp is not getting the signal to switch on.
2. Connect a 12v connection to pin 13 of the bm54. This is for test purposes only, so do not do this as a permanent solution.
If the voltage is low, then the bm54 is repairable.
This is one type of fault, I'm sure there is plenty of other faults out there.
Post #152504 21st Nov 2012 10:29am
andrew.aa
Baris, I checked the output voltage (pin 13 bm54 to pin 8 DSP) and seems to be ok (12.7v) the radio module work correctly, also because I have no audio from either nav.
do you think the DSP? can be repaired?
Post #153408 25th Nov 2012 7:00pm
Baris
Ok, so the DSP is getting the correct power. Before putting the fault with the DSP, there is one more test to do in the bm54.
Pins 1-8 are speaker outputs, you should only have middle ones connected, which are pins 2,3,6,7. There should be 6 volts coming out of these. Alternatively, if you have some spare speakers, connect up the back of the bm54 connection and see if you get any sound.
Post #153633 26th Nov 2012 1:58pm
Better off without DSP anyway sounds awful....
Post #153635 26th Nov 2012 2:18pm
andrew.aa
Thank you Baris , I will check now, bm54 speaker output, can I connect spare speaker into dsp connector?because I can't get the radio connector . alternatively can be fit Harman Kardon logic 7?
Post #153831 27th Nov 2012 1:00pm
andrew.aa
I tried to see if spare speaker can work connected to pin 4- 9+ and/ 5- 10+ on the DSP conector (X18773/26) but no result, AND no audio. I tried with dsp not connected),. I noticed that the radio time during the search does not find anything. in this case can be the radio module the problem.. I would know because just yesterday I took a dsp on ebay, and I would not be useless
Post #153879 27th Nov 2012 4:55pm
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
I appear to have lost some of the channels, the sound is full of base and muffled, any chance of this being fixed by you baris?
Regards
Steve
Post #167536 25th Jan 2013 5:46pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Check the plugs that go in to the amp, the pins are most likely corroded due to water ingress or the amp circuitry is damaged
Post #167616 25th Jan 2013 8:30pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Steve,
I suffer the same as you on occasions. Mine seems like a lose wire or something as it works fine for a while, drive over a couple of bumps and I get a crackle and then sometimes all the car speakers cut out - I;m left with just base from the boot area ( I think ). Turn the radio off using the push button and then straight back on again and it all comes back. sometimes for days and sometimes for minutes until I hit another bump (or a tight left turn funnily enough !)
Baris - Is this more likely to be the dsp amp.? Ash
2016 SDV8 AB
Post #167842 27th Jan 2013 8:25am
Baris
Andrew, if you have no speaker output from the bm54 it very well must be the bm54. What do you mean by, you can't find radio stations? Can you search for radio and flick through the modes?
Comports, that sounds like a DSP fault, if you can still control radio stations. Check the pins on the connection.
Steve, I recently had someone come with the same symptom, and the fault was with the DSP. Had to replace the DSP in the end.
Post #174962 28th Feb 2013 11:13am
comports
Update Baris
My sound went again tonight. I have full control of the radio stations still and everything else up front. I do hear the radio still but it seems only the low (bass) channels. They do still come from the car door speakers but very quiet and bass'y.
Does this suggest the DSP is on it;s way out, can it be repaired by you or is it a replacement I;m looking at.? Ash
2016 SDV8 AB
Post #175293 1st Mar 2013 7:48pm
Turn the DSP off - sounds better
Post #175294 1st Mar 2013 7:52pm
comports
I wonder if that will confirm the issue though. If i just turn off the DSP (via the screen options) and see if the radio/sound cuts out again. If not then it's deffo the DSP AMP that's goosed..? Ash
2016 SDV8 AB
Post #175295 1st Mar 2013 7:54pm
