![]() | Home > Technical (L322) > [SOLVED] How do I test if my Auto Dipping Mirror is working? |
With a tinted rear window, headlights aren't as bright as with a normal rear window.
Shine a torch onto the mirror sensor |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
Are we talking about dimming or dipping ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35530 ![]() ![]() |
it'll be dimming...i got the same problem with my tints..kinda makes the auto dip redundent... ... - .- -.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Mine only seem to work when there isn't street lighting around, making me think it's something in the mirror that governs it (a bit like the auto lights). |
I mean the rear view mirror (the one fixed to the windscreen).
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
The photocell is the little round circle in the top center of the rear view mirror. A torch should do the trick. It should dim both wing mirrors and the rear view mirror. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Can't you override it by turning the red light at the bottom of the mirror one way? Sure that's what the manual says for manual dipping. |
It works.
