Home > Technical (L322) > Juddering
i've always filled from supermarket pumps and only once have a had a very slight judder but a dose of wynns [or similar] in the fuel tank and it hasn't happened since ,but it could be a coincidence though and the wynns had no effect... ... - .- -.
Post #149957 6th Nov 2012 10:59am
TugRR
Don't be brushed aside by excuses.
Personally, I try to stay away from supermarket fuels, but if they were that bad, they wouldn't be allowed to sell the stuff.
Know your rights as a consumer - that is what will sort your problem out. I suggest you read your warranty policy carefully and look at something like "honest john" through the Daily Telegraph website - there is specific information for these issues.
I'm not going to end with "good luck" because that's not what you need - knowledge is power !
Thumbs Up Where do you go after one of these . . . ?
Post #149958 6th Nov 2012 11:05am
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Thanks for both sets of advice i'll have to point out that the diesel advice came from the dealer I bought the car from not where the car is currently having diagnostic checks run on it.
Warranty read and swotted up on, i'm not a pushover in car dealers.
(I got banned from BMW years ago for these reasons. (another story!)
I'll keep you posted when the diagnostic garage calls me later. Reading honest Johns now Thumbs Up
Post #149959 6th Nov 2012 11:12am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Juddering
crookedm wrote:
The car starts fine but does a kind of juddering motion. Someone suggested this maybe the air suspension recharging. However when I drive it it feels almost like its stuttering, black smoke although not a lot is also visible. It then rights itself and I drive off normally.
This only happens on a temporary basis the only thing I've noticed is the temperature being below 7 degrees.
It sounds to me, if it's only happening from startup and when the temperature is cold that maybe you've got a glowplug or two not working.
They are not expensive and should be treated as consumable items really - they are about the same to change (in terms of complexity) as a spark plug.
It would make sense, then as the engine warms up, the cylinders without the assistance of the glow-plug (really a heater plug as a glow plug is something specific to semi-diesels), would eventually join in with the others anyway.
I'd be inclined to pop a full set in - especially with a forecast of colder weather to come.
Post #149962 6th Nov 2012 11:35am
crookedm
Interesting, I did think it was down to the temperature but it happened on saturday when it was a practically tropical 9 degrees. I will mention it to the dealer later on dependent on what they come back with but again another avenue to persue. May just replace them for the hell of it for piece of mind anyway.
Post #149973 6th Nov 2012 12:59pm
crookedm
Back from the dealer, interesting times ahead I think
At first they couldn't find a problem (nothing came up on the diagnostic checks) so they investigated further and want the car for 3 days next week to strip the engine down. They managed to replicate the fault and a load of black smoke kicked out into the garage. So I've left them to have the conversations with the dealer who sold it to me and discuss who pays. I told them I bloody wont be, I've only had the car 13 days!
They did say more about the problem, but I'll make a fool of myself describing what they said! Either way the car is drivable, all be it occasionally kicking black smoke out and juddering. I wish I could find a link to how the 3.6 tdv8 engine worked!
So far though impressed with the dealer and their handling of this.
Just found this
http://www.dieselpowermag.com/features/090...ewall.html
It was something to do with one of these, although not showing up as problematic one of them is deemed to be causing the problem;
"The cylinder heads are cast from aluminum and feature dual overhead camshafts with four valves per cylinder"
Post #150033 6th Nov 2012 8:01pm
I've heard of a few problems with the EGR valves on the TDV8s
Post #150053 6th Nov 2012 9:05pm
crookedm
You hit the nail on the head! Warranty company coming out on Monday to approve the work - apparently mine has a problem so its being replaced.... all under warranty.
Out of interest how much do these cost (should I not have had a warranty in place).
Post #151522 16th Nov 2012 12:28pm
Don't know the cost but it's a c Censored t of a job on the TDV8
Post #151524 16th Nov 2012 12:47pm
crookedm
I was guessing that the labour costs would be er quite high!
Post #151541 16th Nov 2012 2:46pm
crookedm
Egr valves replaced and car it juddering. Took them a week to do which cost me on insuring the courtesy car, fuel and diagnostics fee. Censored but fixed.
Post #153037 23rd Nov 2012 9:28pm
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Which dealer did it ?
I am having occasional rough idle and judder....... Sounds similar. Got a LR warranty, so will be making use of it. 2011 Stornaway Grey 5.0SC Autobiography
Post #153267 24th Nov 2012 10:56pm
crookedm
Hunters Chester wasn't overly impressed but the works done and the judder is no more!
Post #153269 24th Nov 2012 11:00pm
Let us know if you continue to have no issues, this type of thread is going to be increasingly important as more and more TDV8s change hands and become more affordable. Discovery 4 HSE
Post #153340 25th Nov 2012 10:00am
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I have a similar juddering when on low throttle inputs and at low speed. Thought it might have been torque converter. Interestingly, diagnostics showed an intermittently faulty EGR valve, which was causing a greater than normal throttle lag wen pulling off from stationary.
Reading this thread though, perhaps it is the EGR valve.
Essex 4x4 (an excellent and highly recommended Indy specialist - all ex Land Rover Master Tech's) quoted me just under £500 all in to replace the faulty EGR valve.
Was going to leave it until the other one started to have problems but if it would solve the juddering, I might go ahead and get it done.
Will report back to this thread if I do. -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #153513 26th Nov 2012 8:43am
