![]() | Home > Technical (L322) > more electrical problems |
Sounds like its time for a new battery |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
or alternator, or final stage resistor, just like me! MY2010 TDV8 Vogue Ipanema Sand
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Ok a quick update.
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Abs light should go out if you turn the steering lock to lock after the loss of power 2003 Vogue 4.4 V8 Java Black |
mick79 Member Since: 24 Nov 2012 Location: Hampshire Posts: 42 ![]() ![]() |
Second that lock to lock will cancel those out. Cheers mick Owner of a bottomless pit, Sorry i mean range rover l322. |
That did work today but...
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I would go for a new battery. I just got a new Bosch S5 £113 with 5% cash Bach using quidco. It's a big mother and car starts easier and seem to have less electrical gremlins. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Intresting. The battery is quite new but worth looking at.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8703 ![]() ![]() ![]() |
If looking at batteries, dont forget if you order online from euro car parts you can use the discount codes for 25% off even on click and collect.
If batttery quite new, worth getting the alternator and circuitry checked out .
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 ![]() ![]() ![]() |
Double check the battery has the correct amperage for the vehicle. We've had a few recently where they have been fitted with smaller batteries from the likes of Andrew Pages etc. If you need any advise I'm only in Leeds just give me a call.
Great, will do mate.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Battery age is no guarantee of condition. I had to have a 110 amp/hour Bosch battery replaced after 11 months as it was running out of amps. Voltage was OK according to the multimeter, but still had issues with electrics on start up. (Alternator was also new last year and is performing correctly and reconditioning charge with a ctek couldn't save the Bosch battery. Interestingly the original 5 year old battery which was almost entirely discharged when the alternator failed last year is almost 100% restored after being reconditioned with the ctek) |
I don't rate the Bosch ones that highly anymore. They don't seem to have the reserve you get from a genuine or other makes. We are been replacing units with the new AGM Banner batteries with good results.
