Home > In Car Electronics (L322) > 02 satnav question?
MarkBrand
United Kingdom 2005 Range Rover Vogue Td6 Java Black
02 satnav question?
What satnav does an 02 ffrr use? Will a navteq 2007 disc work in it? Or will it mess up?
Post #151672 17th Nov 2012 12:51pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
02 is a CD and 07 ia a DVD me thinks
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #151677 17th Nov 2012 1:08pm
mjdronfield
If the unit in your car has not been upgraded, it will be a Mk3 BMW sat nav system, as mentioned above, utilising the CD format disk.
You can upgrade to the Mk4 unit, its a direct swap, and uses a DVD based system.
They both use Navtec software I believe.........
Visually, the only difference is that the Mk4 unit has a DVD logo on the front.
There is a Mk4 unit here, and seems to be a reasonable price.........
http://www.ebay.co.uk/itm/BMW-MK4-GPS-DVD-...0792531290 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151684 17th Nov 2012 1:48pm
Errrrr...
Might be of some use to you, they don't change that much.
http://www.fullfatrr.com/forum/topic12896.html
Post #151692 17th Nov 2012 4:04pm
mjdronfield
So long as you don't have a Mk4 unit, nicedayforit's map disk will be fine.
I only posted about the Mk4, in case the 2007 disk was for the Mk4.
Apologies if it mudded the waters slightly.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #151695 17th Nov 2012 4:27pm
Post #151697 17th Nov 2012 4:54pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Slightly related question..... (sorry for hi-jack)
My Mk4 screen says V4-0/00 for the firmware - is this the full version V32 firmware? I seem to have seen a V32.2 version mentioned (V4-0/02 I think) that works with the 2012 maps disc.
Can anyone confirm or deny that for me?
thanks "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #152108 19th Nov 2012 5:53pm
mjdronfield
Hi MrP.
I believe you have the V32 installed, like I have.
There are modified versions of this software about, and the version is upgraded so the unit will install it when you insert the CD.
It is against forum rules to discuss and post links for "pirated" type software downloads.
Personally I'd stick with the genuine V32, as I have read of modded firmware locking the unit up.
Stay with the original mate.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #152130 19th Nov 2012 7:28pm
MrP
Sound advice as always. Thumbs Up "On first name terms with my local Dealer......now."
Post #152141 19th Nov 2012 8:14pm
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Is the an uptoate map for the mk3 unit?
Steve
Post #152145 19th Nov 2012 8:29pm
