Home > Wheels & Tyres > Squirming
mudknight
2003 Range Rover Vogue Td6 Java Black
Squirming
Hi, I've just fitted two new tyres on the front , the rears have around four mm left ,, since doing so the car seems to squirm , as if I've fallen into the ruts in the road off the trucks , or hitting a patch of ice ,, if I accelerate its noticeable then too, wheel nuts checked , tyre pressures checked , any ideas ? It's a 2003 td6
Post #152034 19th Nov 2012 12:49pm
What make are the new tyres? Shocked
Post #152045 19th Nov 2012 2:00pm
mudknight
They are kuhmo ,,are they any good ? Rear are wrangler
Post #152056 19th Nov 2012 2:28pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
IMHO it's always a false economy to change tyres two at a time on a 4X4 - especially if they aren't matching tyres in the first place.
I suspect the dodgy handling is down to mis-matched tyres, made worse by the different rolling diameter of new versus worn, mismatched tread patterns etc.
Get all four the same type and you'll probably be OK. Never worth skimping on tyres or brakes with a 2 tonne car.
Post #152067 19th Nov 2012 3:05pm
in an ideal world i agree with Simon ^^^ but economics sometime dictate that you can only change 2 tyres at one time....
check that both tyres are fitted properly on the rim , recheck pressures and if the wheels are fitted on the range properly...you could also put these on the back of the range to see it solves your problem....
..if all else fails ,go back o the dealer and complain... ... - .- -.
Post #152071 19th Nov 2012 3:23pm
Simes
Economics... Pah...
Just buy four tyres and be done with it. You don't want them spending your savings on a funeral.
Post #152073 19th Nov 2012 3:29pm
Laughing
Op's only 21 years old.. Laughing ... - .- -.
Post #152074 19th Nov 2012 3:31pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I've got Kumho KL12's on mine but both changes have always been all 4 at once. I've never had a squirming problem on the 4.4 or the 4.6 turbo (5 sets on the turbo)
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #152138 19th Nov 2012 8:05pm
JAYBOY
Try putting the new ones on the back that should solve your problem.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #152143 19th Nov 2012 8:26pm
ebajema
When was the last time your alignment was adjusted (all 4 wheels !!!!) ??
Also have your suspension checked for play on the rubbers etc. Just to be sure. MY 2010 5.0 SC Galway green and sand interior!!
Post #152152 19th Nov 2012 9:15pm
