![]() | Home > Maintenance & Mods (L322) > 4.4 gas jag need info on removing fan |
Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42 ![]() ![]() ![]() |
Yesterday, a whining noise started that goes up and down with the speed of the motor. It used to only happen when the a/c was on but now it's constant. Accordingly, I referred to the new manual using Alldata which is the exact information that LR provides on their pay site. In order to get to the belts and pulleys, I need to drop the coolant and remove engine cooling fan and then the fan shroud. Fun stuff. I have spoken to some people that know more about this than I, but there is conflicting info because of the BMW v. Jaguar engines. I have some questions:
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Water drain is on the right hand side of the rad as you stand looking in at the engine compartment with a red cap...
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
I had exactly the same issue and it turned out to be the A/C compressor. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
Spray a little WD40 onto the bearing of the tensioner roller (make sure it does not go onto the belt !!!).
the guide is here http://www.garyelliott.co.uk/prestige_cars...ission.pdf |
Well I gave it a few hours today in between getting other things done. I have everything out except for the drivers side bolt on the shroud. I still need to undo the fan but I don't know if I can get it back on again. Bloody torx screws are a PITA as well. The drain cock was on the passenger side (left hand drive) and a 1/2" clear plastic hose made draining a snap. Everything else is as per the instructions. I'll have another go at it tomorrow. I have until Thursday to fix it myself or it goes to the shop. and we all know how they love to fix things that someone else has take apart.
