Home > Maintenance & Mods (L322) > 4.4 gas jag need info on removing fan |
Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42 |
Yesterday, a whining noise started that goes up and down with the speed of the motor. It used to only happen when the a/c was on but now it's constant. Accordingly, I referred to the new manual using Alldata which is the exact information that LR provides on their pay site. In order to get to the belts and pulleys, I need to drop the coolant and remove engine cooling fan and then the fan shroud. Fun stuff. I have spoken to some people that know more about this than I, but there is conflicting info because of the BMW v. Jaguar engines. I have some questions:
12th Nov 2012 10:19pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Water drain is on the right hand side of the rad as you stand looking in at the engine compartment with a red cap...
13th Nov 2012 8:31am |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
I had exactly the same issue and it turned out to be the A/C compressor. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
13th Nov 2012 9:21am |
Spray a little WD40 onto the bearing of the tensioner roller (make sure it does not go onto the belt !!!).
13th Nov 2012 9:30am |
the guide is here http://www.garyelliott.co.uk/prestige_cars...ission.pdf |
13th Nov 2012 9:57am |
Well I gave it a few hours today in between getting other things done. I have everything out except for the drivers side bolt on the shroud. I still need to undo the fan but I don't know if I can get it back on again. Bloody torx screws are a PITA as well. The drain cock was on the passenger side (left hand drive) and a 1/2" clear plastic hose made draining a snap. Everything else is as per the instructions. I'll have another go at it tomorrow. I have until Thursday to fix it myself or it goes to the shop. and we all know how they love to fix things that someone else has take apart.
14th Nov 2012 1:21am |
