Home > In Car Electronics (L322) > Got my Mk4 sat nav coming, help please?
This topic is locked: you cannot edit posts or make replies.  Down to end
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Guys
Ive finally got a mk4 for 200quid Thumbs Up
Ive gone through the wiki's and search and read up various bits
from what i understand straight forward plug and play
I wanna do the V32 firmware upgrade and New splash screen ive found the myrangerover site
Has anyone else got any other splash screens?? or any other suggestions?
thanks
Neil
Post #150744 12th Nov 2012 12:33am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
i used the splash screen from matt stevensons web site
http://www.myrangerover.co.uk/MyRangeRover/MK4Firmware1020.html
steve
Post #150749 12th Nov 2012 6:55am
greatw
Neil,
Yup is is straight plug and play. Takes 2 minutes:-)
Just be careful with teh antenna cable as it is quite fragile!
Let me know how you get on with the upgrade.
Once I get mine fixed, that will be the next job!
Cheers
Alex
Post #150752 12th Nov 2012 7:54am
sevy
2002 Range Rover Vogue 4.4 V8 Adriatic Blue
I did the upgrade as per mattspage , ive done it befre on a BMW , his software is excellent , go for it !! well worth the 250 i paid for a mk 4
Post #150960 13th Nov 2012 12:01am
cliffy
Right the drive is in and now ive got a mtec splash screen lol
Ive tried Matt's web page and put the firmware onto a CD and a DVD and its not reading
should the disc be recorded with a bootable start??
Post #151841 18th Nov 2012 2:50pm
cleughy
I just burnt the img onto a cd using imgburn ans it kicked right in.
Steve
Post #151842 18th Nov 2012 2:52pm
cliffy
So just a normal CDR steve?
Post #151844 18th Nov 2012 2:55pm
mjdronfield
You need to burn it at the slowest speed possible, and I understand the firmware already installed will need to be a lower version than on the update disk, or the system will not update itself.
I have this splash screen ;
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151847 18th Nov 2012 3:09pm
cliffy
the slowest this laptop will burn at is 10 is this to fast???
I know its got a older version as it hasnt got the full post code option on the first part
Post #151849 18th Nov 2012 3:12pm
mjdronfield
Not done it myself, but 1x or 2x seem to be the suggested speeds, in Mode 2, with a good quality CD-R.
Sounds like you should be OK with the firmware versions though.
Bit more info here ;
http://www.xoutpost.com/electronics/naviga...ver-4.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #151851 18th Nov 2012 3:20pm
cleughy
It's a tiny file, I used 1x on a cdr
Post #151854 18th Nov 2012 3:36pm
cliffy
right 10 discs later and still no joy and recording at 1x not a happy bunny
Post #151870 18th Nov 2012 5:11pm
cleughy
Maybe the brand of disk then, the drives are picky with the DVDs for sure
Post #151878 18th Nov 2012 5:31pm
just to remind you chaps that pirating software for use in your range is frowned upon by Martin the site owner....im gonna have to lock the thread so that no more links or sites are shown here.... ... - .- -.
Post #151890 18th Nov 2012 5:54pm
This topic is locked: you cannot edit posts or make replies.  Back to top
