Home > Technical (L322) > TD6 Tuning Question |
zetjester Member Since: 01 Apr 2013 Location: Northamptonshire Posts: 48 |
[quote="mjdronfield"]The GM gearboxes in the Td6 tend to fail due to the valve bodies being made from slightly softer aluminium. The bores wear and deposit metal bits in the oil, which thus causes more wear. The wear causes a drop in hydraulic pressure which tends to make the clutches ? work a bit harder...... the only real fix is a valve block with the Sonnax upgrade, which effectively lines the bores with harder steel and stops the wear.
11th Apr 2013 12:40am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7775 |
I started to do a bit of research on it, and found that some did standard rebulds, some had the sonnax upgrade, but not to all the valves. I'm not a gearbox expert, so have no idea why you would not do all the valves, and whether you indeed have to have them all done.
11th Apr 2013 4:51pm |
12th Apr 2013 2:08pm |
