Home > Technical (L322) > TD6 Tuning Question |
When I had a TD6 I used Pentagon who are SuperChips agents .
28th Oct 2012 11:10am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
http://bellautoservices.co.uk/bas-remap-interface/
28th Oct 2012 12:55pm |
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 |
Thanks guys,
28th Oct 2012 4:48pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2634 |
I have the Tunit box fitted, although never driven a standard car, performance is more than adequate for the size of car. Whichever route you take, a very worthwhile upgrade. |
28th Oct 2012 5:48pm |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 |
Word of Warning!!!!!
31st Oct 2012 9:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
Dont agree... Most cars i look after are tuned in some way and no more failures then without... Craig |
31st Oct 2012 9:20am |
Oh god.....are they really that bad?
31st Oct 2012 9:22am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7774 |
The GM gearboxes in the Td6 tend to fail due to the valve bodies being made from slightly softer aluminium. The bores wear and deposit metal bits in the oil, which thus causes more wear. The wear causes a drop in hydraulic pressure which tends to make the clutches ? work a bit harder...... the only real fix is a valve block with the Sonnax upgrade, which effectively lines the bores with harder steel and stops the wear.
31st Oct 2012 11:03am |
I don't know if my car has had a gearbox replaced......it's done 119k miles and seems ok so far....but then I've only had it a few days!!!!!!!
31st Oct 2012 7:05pm |
I also think,if you get a proper remap, it doesn't put your gearbox at any further risk.
31st Oct 2012 11:03pm |
I thought the extra torque created by a remap puts strain on the auto box? |
1st Nov 2012 5:02am |
I started a thread about renewing my warranty, but it appears from their web site that they only deal with the motor trade, could be wrong.
1st Nov 2012 10:04am |
Lighty Member Since: 14 Oct 2012 Location: Manchester Posts: 7 |
The most important thing with the boxes on these things is make sure you service the bloody "Sealed for life" thing!!! It costs me 80 quid for new gearbox filter oil and all orings/gaskets and new bolts for sump. Takes an hour to do it properly I put it on the ramps drop it, clean it all out put new filter in and oil in run it for a week then the following weekend ill flush that new oil back out and replace with new. I do that once every year if I can be arsed but if I waited 2 years itd be fine too. DO that and youll stand more chance of it lasting at least. |
2nd Nov 2012 6:52pm |
Ok......I took the plunge.......and ordered a tuning box from from Race Chip in Germany - the company that supplied my friend with one 4yrs ago for his car.
7th Nov 2012 10:01am |
