Home > Technical (L322) > steering column adjuster. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
this link is just one of many threads re the steering column...it is a common problem...i hope it helps.
5th Nov 2012 2:09pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
@ Muffster, if you can describe me how to load pictures in the reply, I can show you the part you need, only a handmade screw! Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
5th Nov 2012 3:53pm |
Wheres Mick when someones talking about not being able to get something IN and OUT?!?! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Nov 2012 3:54pm |
mr meerbush, how to post pics...
5th Nov 2012 5:26pm |
Hi, you can see the part, what is defect, on Gallery, picture 1/4434, the black part under the t of the word motor, it is not to buy singular, only in handmade-rebuild! Can give you help, regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
5th Nov 2012 6:20pm |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 |
I've read through some old threads and the more common issue seems to be with the tilt mechanism.
5th Nov 2012 7:09pm |
http://www.fullfatrr.com/gallery/displayim...;pos=-6184
5th Nov 2012 7:31pm |
Thanks ebajema, my english is not good enough for send pictures in my post..., it is the little black part, if I get an e-mail adress of muffster in the next reply, I can send a picture to muffster. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
5th Nov 2012 7:42pm |
ebajema
5th Nov 2012 8:16pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
I believe that the nylon white clip that holds the motor onto the spindle becomes brittle and snaps over time (this happened to mine). If you take off the panel which is the 'ceiling' to the footwell trim you should be able to see it. I fixed mine with a cable tie and it works fine! Hope this helps 2003 Vogue 4.4 V8 Java Black |
5th Nov 2012 8:19pm |
I think what Uli (Meerbusch) is referring to is the Reach Motor text on the picture. If you look directly below the t of the word motor, you see the spindle of the motor going through a black nut (or threaded block) that is slotted into the aluminium frame.
5th Nov 2012 9:24pm |
Great,
5th Nov 2012 9:30pm |
Exactly, was I said, and ebajema sees, is the problem, the black nut. I have made some examples here for friends in germany, one hour work with black plastic (nylon 12mm) per piece, the official bought also one ), the complete steering column costs about 2.200,-euro, only changable complete L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
5th Nov 2012 9:50pm |
Meerbusch
6th Nov 2012 12:12pm |
