Home > Maintenance & Mods (L322) > gear linkage maintenance - BMW 4.4 V8
Before I get under the car is anybody aware of the exact location of the Gear Linkage on BMW engined 2003 4.4 V8 Petrol please?
I know where it is on TDV8/TDV6 but have not greased a 4.4 V8 before......
Thanks
Gaz
Post #149612 3rd Nov 2012 4:14pm
ebajema
Looking at the workshop manual for the 2002-2005 models, the ZF gearbox has a cable from the selector level to the gearbox. The gearbox has a lever that controls the manual control valve in the gearbox. So no real linkage. If things are going "a bit heavy", then I suggest to lube the cable with a good lubricant like Molykote Multigliss or the likes. A bit of grease on the cable connections to the levers won't go amiss either. MY 2010 5.0 SC Galway green and sand interior!!
Post #149631 3rd Nov 2012 8:54pm
This is what I was after I knew they all have a linkage that needs greasing/oiling or replacing on older cars....
http://www.garyelliott.co.uk/prestige_cars...ission.pdf
Post #149671 4th Nov 2012 10:20am
Appears to be on the passenger side on the 5HP24......
Which is why blindly spraying the drivers side did not help.... Embarassed
Post #149672 4th Nov 2012 10:22am
Image must be wrong its actually on the Drivers side were it should be!!!!
Post #149734 4th Nov 2012 7:22pm
ebajema
So did the blindly spraying help or not ??? Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #149735 4th Nov 2012 7:24pm
Not I am afraid I think it may be a blocked lower radiator problem causing Gearbox Overheat.
Gary
Post #149737 4th Nov 2012 7:28pm
ebajema
Ouch, that means a bit of extra work to be done then. MY 2010 5.0 SC Galway green and sand interior!!
Post #149739 4th Nov 2012 7:39pm
Yes all in the cause as they say....
Post #149740 4th Nov 2012 7:40pm
ebajema
Well it is not a new car so things just need to be done, they don't live forever. MY 2010 5.0 SC Galway green and sand interior!!
Post #149743 4th Nov 2012 7:46pm
