![]() | Home > Technical (L322) > Won't start - Immobiliser problems ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
when you put your key in it should make a clicking /whir noise, this indicates the gear release and immobiliser are off. ... - .- -.
When you stick the key in, the immobilizer "releases" the electric steering lock (that is the click you hear in the steering column).
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 739 ![]() ![]() |
Yes it does do that 'normal' sound, but this is a different one it makes (when the key is in the cranking position)
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Is it the chatter from the starter solenoid? Your new starter might be duff |
see if the connections to the starter are sound... ... - .- -.
The sound is from the immobiliser - you can also feel the high pitched vibration if you hold it when it's buzzing while cranking.
I don't know the L322 system, but I would have thought it unusual for an immobiliser to make a sound or vibrate |
so it does sound like the immobiliser then, Dan @ duckworths will give you a competitive price.. ... - .- -.
......you've obviously checked the wiring to the immobiliser... ... - .- -.
Yes, I'm thinking I may need to bite the bullet and book it in at the dealers (If it will start) |
have you tried the spare key like Ebajema suggested..and i would recheck all connections to the battery , starter and immobiliser even going as far as dis/re connecting the battery...... ... - .- -.
Unfortunately the spare key has never worked since I got the car 2 yrs ago, battery was flat at the time, and when I replaced it, it wouldn't work - so it's been kicking about in the back of drawer ever since (another job I never got round to doing)
So when you move the key to the cranking position the starter motor does not turn?
Faulty starter relay? |
