Home > Technical (L322) > Bi Xenons or not
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
Bi Xenons or not
Can anyone help - I have two lamps on the front of my FF which never illuminate within the side light housing.
They do not look like a normal lamp, are they the Bi Xenons which are supposed to work when turning?
I have looked to see whether they come on with different switch configurations or when the steering wheel is turned but they do not..is this something that can be checked with the IID Tool?
Any ideas or suggestions - the FF is a 2006 TD6 many thanks
Post #149037 31st Oct 2012 8:57am
Do they have Bulbs with a black top on or are they a chrome cover? If a chrome cover then your car is not equipt... If a bulb then either you fall into the category "they have never worked from factory" or something has broken... Do your lights move from side to side round bends at night?
Craig Thumbs Up
Post #149039 31st Oct 2012 9:17am
Cash2
Hi Craig the bulbs have a black top and no the light does not move from side to side round bends at night.
Post #149045 31st Oct 2012 9:42am
Then unfortunately sir them dont work!
Craig Thumbs Up
Post #149246 1st Nov 2012 12:11am
Cash2
Does anyone have any suggestions or a starting point for testing or checking?
Can this be checked with the IID Tool?
Post #149252 1st Nov 2012 7:41am
Lighty
Do you have two big Ballast units 1 outside each light? Should have a sticker on it woorning of high voltage, be very careful working around Xenon ballasts as there is a nice 20,000 Volts in there that will hurt you a lot!
Post #149581 3rd Nov 2012 9:23am
Cash2
Hi Craig I may have been hasty and misinformed you as to the colour of the bulbs - they looked black when I first looked but having looked again they appear chrome.
Can you tell me what the difference is between the black and chrome?
Should they illuminate as a normal lamp?
Many thanks
Post #150246 8th Nov 2012 5:17pm
daveo
I think you will find you are looking at the blanking plugs for the cornering lights, they have nothing to do with the bi-xenon’s they are in fact part of the adaptive system, if your car has it, the adaptive system works with your head lights and moves the head lamp lens, you will see this when you start your car with the lights on, if you are close to a wall you will see the lights move up and down then left and right, if you have this the you may have cornering lights and these work at low speed when turning, IE going into a drive or out of a car park. You are looking for halogen bulb, they can be seen quite clearly, and if you can’t then I would say you have the blanking plugs fitted,
Just one thing, cornering lights have burnt many a headlight due to the wattage and heat generated. V8 facelift Range Rover Autobiography 22" wheels.
Post #150288 8th Nov 2012 7:16pm
Many thanks
If they are chrome then they are blanks my friend...
Craig Thumbs Up
Post #150317 8th Nov 2012 11:26pm
Cash2
Thanks to all for the replies
Post #150361 9th Nov 2012 9:29am
