![]() | Home > Technical (L322) > How soon should my Diesel L322 take to warm up |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
mines about 5 miles to get the halfway needle but the 'heat' starts after about 1/2 miles.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I don't think mine is miles different.......... 2011 Range Rover Vogue SE 4.4 TDV8
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
About the same, sooner if my FBH kicked in.... |
About the same usually unless i use timed climate.
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Ive read much on here and other forums about the FBH, apparently all TD6's have it fitted, but is only controllable if you have a fob or a screen.
The FBH just comes on to warm the car up when starting from cold. There is a section on FBH Q & A in the wiki about how (and when) it works.
Thanks mjdronfield
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I believe if you get the front entertainment module's software updated, you will be able to use timed climate on the touch screen.
Mick's FFRR is up to temperature by the time he gets from his house to the main road |
Yeah but he has a 10 mile private drive...... |
As if … |
C'mon Gaz don't exaggerate! Its only 3 miles once you take into account the car parks for his minions and the storage areas he has ![]() He's Mick from the Bloc on his way to the shops ![]() Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Surely he has someone warm it up for him. |
