Home > Maintenance & Mods (L322) > Brake Pad change
greatw
Brake Pad change
Hi, Might be a daft question, so please be kind Very Happy
I need to change teh front pads on my FF. Just wanting to check that there is none of the messing I had with my Audi. i.e, just push the pads/ pistons back and replace old school. No computers required.
Thanks in advance
Alex
Post #148278 26th Oct 2012 12:33pm
Very easy! Chances are you'll break the pad wear sensor (only one side), so you might as well get one at the same time as the pads! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #148279 26th Oct 2012 12:35pm
ebajema
No computers required as far as I know. I had the rear callipers and pads replaced here in Nigeria by our mechanics and no issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #148280 26th Oct 2012 12:36pm
greatw
Thanks Guys,
I was about to get the pads and thought I had better check.
Oh well, looks like that's my job for tomorrow then Very Happy
Post #148290 26th Oct 2012 1:16pm
You will/may have to push the pistons back a bit to get the new pads in, and therefore also may have to remove a bit of brake fluid from the master cylinder (or catch the overspill). It is quite easy to make up a piston pusher - see here
Thumbs Up .
Post #148335 26th Oct 2012 3:32pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
you will have to clear the message on your dash as well gone fishin'
Post #148366 26th Oct 2012 4:57pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Only if the wear sensor has been rubbed thru but if its being replaced there will be nothing on the dash onto no6 Range Rover
Everyone needs a hobby
Post #148371 26th Oct 2012 5:02pm
andyboy
Changed my pads all round and the sensors and i had the "check brake pads" message. gone fishin'
Post #148396 26th Oct 2012 7:31pm
Light should go out once the new sensor has been replaced
Post #148402 26th Oct 2012 8:05pm
fisha
very simple to change the pads. As for a calliper pusher, just get a halfords one, it does the job fine.
To push the calliper piston pack, I normally open up the bleed nipple when pushing it back to let the old fluid out. also makes it easier to push in. V8 or else ...
Post #148408 26th Oct 2012 8:45pm
A G-clamp works fine for me when pushing the piston back in. Previously..
Post #148417 26th Oct 2012 9:14pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Yup - a G clamp worked very well when I replaced all the pads last year.
Post #148424 26th Oct 2012 10:22pm
XL plummers pliers
Post #148429 26th Oct 2012 11:52pm
