![]() | Home > Technical (L322) > Air Compressor Strip down |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Nice work, hope it all holds up |
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 ![]() ![]() |
I cleaned with a green pad, I stretched it by taking it out. It actually sounds a lot quieter. Also the other thing I found out was that land rover put out a bulletin about getting the ecu re flashed with regards to bringing down the pressure down to about 9 bar. Apparently this was due to compressors burning out! I dont know whether the RAC can do this could somebody confirm ??? I can believe it, as mine is currently pumping up over 11 bar !!!! So mine is over working !! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
i've wiki'ed this excellent write-up... ... - .- -.
Thanks Trist, excellent job !!! This definitely deserves a place in the Wiki Hall of Fame |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
VERY VERY good describtion of refit the compressor, I make it on the same way, but I change the rusty springs, the piston-ring, the cylinderhead because of his inside-wash-out, the dryerpatrone and the gaskets. But for refit without any money-invest, VERY VERY good, respect! Of course it is not like new, but better than before. Original full power you can ONLY get with new cylinderhead and piston-ring..., regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
This guy makes new seals for the compressors, he doesn't always have them in stock but if you need one he will do his best to make one for you as soon as possible. Read on various forums about the excellent service he provides. Worth dropping him a message if you are looking for a replacement. |
Yes, I know this ebay offer since years, but only changing the piston-ring is like new brake rubbers on old brake-discs, you NEED the new cylinderhead, because when I always feel at my repairs with my finger inside the cylinderheads, I feel the (german word: Abnutzung) of the head, new piston ring is only for some month, believe me! Made about 70 compressors of Range Rover like new, only the ring I made at my own some years ago, and after 7 month the problem came back..., therefore I decided to repair commercial + professional with ALL!!! parts new, it costs from 115 for a complet set - 165 GBP incl.work and deliver, regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Abnutzung = wear (deterioration) |
Uli I have said that this is not a fix but a temporary fix or at lease to check if the motor is still running(can be done by putting power to it via a 12v battery) or stuck ! Now I know the motor is working it is now time to do the rebuild with the new bits ! Or I could have had new rebuild kit and found the motor is not working then i would have to spend twice. |
I wonder if honing the cylinder with a new, slightly bigger ring would have the same effect as all new parts. Anyone have an idea on how much wear/diameter increase occurs in the cylinder head ? MY 2010 5.0 SC Galway green and sand interior!!
@ ebjema, plastic HONING???????????????????????????????????????? You will be the million�r, if you can plastic honing...., but the idea is correct. But a new cylinderhead costs round 115 GBP incl. all new parts...
Hi Uli, I didn't realize the chamber in which the piston is running was made of plastic, it looks very metallic to me.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I fitted the kit from Meerbusch and its now working perfectly. Highly recommended. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
