![]() | Home > Technical (L322) > Water in spare wheel well |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
This appears to be quite well known fault, there was quite a big thread on it so would be worth putting it into the search function. If i remember correctly it is usually the rear door seal.
Windscreen Dave Member Since: 28 Jun 2012 Location: Lincoln Posts: 29 ![]() ![]() ![]() |
Thanks guys |
If not the rear door seal thn the sunroof drain hole. It normally enters the boot in the rear left (passenger) corner and then overflows the rear panel lip into the spare wheel we'll. temp fix is to shove a rag/tissue in the hole and chane when wet. Stops the water flowing around.
