Home > Technical (L322) > Water in spare wheel well
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Hi all my turn to ask a question. I have just noticed that I am getting quite a lot of water collecting in the spare wheel well. I can't see anywhere where it is coming from and at a bit of a loss. Does anybody have any ideas? Thanks in advance Dave.
Post #148101 25th Oct 2012 5:57pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
http://www.fullfatrr.com/forum/post129922.html
HTH
Post #148103 25th Oct 2012 6:03pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
This appears to be quite well known fault, there was quite a big thread on it so would be worth putting it into the search function. If i remember correctly it is usually the rear door seal.
EVO beat me to it!
Post #148104 25th Oct 2012 6:04pm
Windscreen Dave
Thanks guys
Post #148108 25th Oct 2012 6:15pm
Dolphinboy
If not the rear door seal thn the sunroof drain hole. It normally enters the boot in the rear left (passenger) corner and then overflows the rear panel lip into the spare wheel we'll. temp fix is to shove a rag/tissue in the hole and chane when wet. Stops the water flowing around.
Solution to clearing the drain hole is on here somewhere but iirc involves a long wire, drill attachment and patience. Thumbs Up
Post #148232 26th Oct 2012 9:31am
