Options below:
Personalisable feature Options Note Default Setting System
Wiper slowdown Active / Inactive Step down wiper speed at rest (e.g from slow wipe to intermittent) Only on Non Rain Sensor Cars Active BCU
Autolock repeat disable Active / Inactive Specifiy whether autolocking (speed locking) operates more than once per ignition cycle Inactive BCU
SPE Key 1 Active / Inactive Specify whether key 1 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 2 Active / Inactive Specify whether key 2 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 3 Active / Inactive Specify whether key 3 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 4 Active / Inactive Specify whether key 4 has single point entry Active US/Canada. Inactive RoW BCU
Autolock Key 1 Active / Inactive Specify whether key 1 has autolocking (speed locking) Inactive BCU
Autolock Key 2 Active / Inactive Specify whether key 2 has autolocking (speed locking) Inactive BCU
Autolock Key 3 Active / Inactive Specify whether key 3 has autolocking (speed locking) Inactive BCU
Autolock Key 4 Active / Inactive Specify whether key 4 has autolocking (speed locking) Inactive BCU
Lazy vent Active / Inactive Specify whether vehicle has global window / sunroof opening via key Active BCU
Lazy lock Active / Inactive Specify whether vehicle has global window / sunroof closing via key Active BCU
Lazy lock with remote Active / Inactive Specify whether vehicle has global window / sunroof opening via remote handset Inactive : US / Canada / Australia
Active : RoW
BCU
Auto 2 min relock Active / Inactive Specify whether vehicle automatically relocks after 2 mins of being unlocked and no doors opened Inactive BCU
Panic alarm Active / Inactive Specify whether panic alarm operates via remote handset tailgate unlock button Inactive BCU
Arrival time clock 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Distance units km / miles Depends on Instrument Pack Inst Pack
Distance limit units kmh / mph Depends on Instrument Pack Inst Pack
Speed units kmh / mph Depends on Instrument Pack Inst Pack
BordComputer with ignition Active / Inactive Specify whether BordMonitor (MFD) operates when door opened or when key in ignition Active Inst Pack
Temperature units Centigrade / fahrenheit ºF : US and Canada
ºC : ROW
Inst Pack
Time units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Timer 2 units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Timer 1 units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Range units km / miles Depends on Instrument Pack Inst Pack
Fuel cons units 2 l/100km / MPG - UK / MPG - US km_l : Japan
mpg_us : US
mpg_uk : RHD vehicles with MPH instrument pack
l_100km : RoW
Inst Pack
Fuel cons units 1 l/100km / MPG - UK / MPG - US km_l : Japan
mpg_us : US
l_100km : RoW
Inst Pack
Ext temp warning gong Active / Inactive Specifies whether low ambient temperature (frost) warning sounds Active Inst Pack
Instrument pack language German / UK English / US English /
Italian / Spanish / Japanese / French /
Canadian / Gulf
Depends on Market programmed Inst Pack
Daytime Running Lights Active / Inactive Both this and the 'Dip Beam with daytime running lights' feature needs to be active for DRL operation Active : Non-Canadian vehicles with daytime running
Inactive : RoW (Including Canada)
LCM
Dip beam with daytime running lights Active / Inactive Both this and the 'daytime running lights' feature needs to be active for DRL operation Active : Non-Canadian vehicles with daytime running
LCM
Follow Me Home delay None / 40s / 90s / 150s / 240s Set timeout for any follow me home lights Active : Non-Canadian vehicles with daytime running
LCM
Follow Me Home with dipped beam Active / Inactive Specifies use of dipped beam for Follow Me Home feature 40 seconds LCM
Follow Me Home with rear position lamps Active / Inactive Specifies use of rear position lamps for Follow Me Home feature Active LCM
Follow Me Home with front position lamps Active / Inactive Specifies use of front position lamps for Follow Me Home feature Active LCM
Follow Me Home with interior illumination Active / Inactive Specifies use of interior illumination for Follow Me Home feature Active LCM
Follow Me Home with Licence Plate lamps Active / Inactive Specifies use of licence plate lamps for Follow Me Home feature Active LCM
Follow Me Home with Front fog lights Active / Inactive Specifies use of front fog lights for Follow Me Home feature Inactive LCM
Follow Me Home with Main Beam Active / Inactive Specifies use of main beam for Follow Me Home feature Inactive LCM
Follow Me Home with Rear fog lights Active / Inactive Specifies use of rear fog lights for Follow Me Home feature Inactive LCM
Follow Me Home with Reverse lamps Active / Inactive Specifies use of reverse lamps for Follow Me Home feature Inactive LCM
Default speed dependant volume Option 1 / 2 / 3 / 4 / 5 / 6 Specify automatic volume control (speed dependant) level (1 low, 6 high) Option 2 DSP
Radio Key Memory Enable / Disable Specify whether radio presets are personaliased to remote handset (I.e. each handset has own
presets)
Enable Radio
RDC Number of Sensors Four / Five Specify whether spare tyre is full spare (has RDC sensor transmitter) or spacesaver (no RDC sensor
transmitter)
4 : Vehicles with Space Saver
5 : Full Spare
TPMS
RDC Monitor Number None / Four Specify whether RDC operates on all four wheels or not Four TPMS
PDC Audible Warning Active / Inactive Specify whether audible warning sounds momentarily when PDC selected Active PDC
PDC Rear Volume Option 1 / 2 / 3 / 4 / 5 / 6 Specify rear PDC sounder volume level (1 low, 6 high) Option 3 PDC
MY10 3.6 TD V8 Autobiography
635 d cab
55 Vogue se
TVR Cerbera
