![]() | Home > Maintenance & Mods (L322) > Gearbox Software Update Hard shift |
Hi Alex, I am in the middle of trying to solve this issue and I know there is another member that has a shift issue as well. My problem is the 3-4 shift and it is the same as what you mention, like the gearbox does not know to change gear or not.
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Alex, had my 06 SC reflashed at Guy Salmon LR in Aylesford. Phil Watson the service manager who I have known for about 10 years is most helpful. The reflash cured the 2nd to 1st downchange joit, which i think is called rollout.
Alexdyer Member Since: 11 Feb 2012 Location: Bluebell hill village Posts: 24 ![]() |
Hi Stewart thanks for your reply.
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I too have had this problem with my 2005 s/c. It has done 145k and last year I had:
Alex, I had some other work done so I don't know the cost of the reflash. Perhaps give Phil a call and ask him how much just for a reflash. How many miles do you have on the clock, mine had 51k when reflashed.
I have got 76000 miles on the clock
http://www.lrparts.net/pp/RANGE_ROVER_L322...H_OIL.html
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
A gearbox flash resets the adaptions as it wipes the ECU's memory. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
I have just had the software updated on my 08my tdv8, the shifts from 1-2 and 2-1 are slightly smoother now than they were before.
I have got access to a autoboss v30 to have the adaptions reset however I was under the impression that there is actually upgraded software that the dealer can install!
Yes, it is a software update not just a reset. There is nothing that can't be fixed with a hammer😜😜
