Home > Maintenance & Mods (L322) > Bleeding brakes - please help |
MBR Member Since: 29 Sep 2012 Location: Tongue Posts: 23 |
Hi all,
16th Oct 2012 5:41pm |
Hi,
16th Oct 2012 5:50pm |
If the pedal feels fine on the road then I would leave it |
16th Oct 2012 6:19pm |
Thanks, I will book it in for an MOT and see how I go on |
16th Oct 2012 7:23pm |
Mine does the exact same pedal to the floor on start up but when travelling the brakes work fine , have to admit at first i thought there was something wrong too .. |
16th Oct 2012 7:42pm |
I noticed mine did the same thing when I bled the brakes, I thought I had a leak at one of the joints as I had replaced flexi pipes and calipers, but once out on the road the brakes are shiit hot...Nothing to worry about |
16th Oct 2012 8:12pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
As been said mines the same. Feels but if I put that much force into the peddle while driving I would be scraping my face off the steering wheel! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
16th Oct 2012 8:26pm |
many thanks for all your replies. It makes me feel much happier to know that this is normal. I have spent the last two weeks checking and double checking everything I can think of.
16th Oct 2012 8:55pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Pedal creep by applying continuous pressure to the brake pedal is very common on diesel engined cars due to the vacuum available from the engine mounted vacuum pump. Basically there is generally to much vacuum available.
16th Oct 2012 9:12pm |
Hi all,
15th Nov 2012 10:28am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
+1 on what nicedayforit said spot on
15th Nov 2012 7:02pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Same problem but on a 2004 L322 4.4 petrol
12th May 2015 8:48am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
One of the ways of testing if your brake power assistance is working is to have pressure on the pedal when starting the engine. If it sinks a bit further then the servo is working if it doesn't then there is a possible problem with the servo.
12th May 2015 10:24am |
Hi thanks for the return.
12th May 2015 12:45pm |
