Home > Maintenance & Mods (L322) > Heated seats swap for Heated and cooled
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Hi
I have a late 2006 TDV8 which We have swapped the interior for the later perforated leather seats which are heated and cooled I have also swapped the 2 centre control pannels so I now have the correct Heated cooled operating switches.
The seat motions work no problem and all the wiring plugs in with no issue but the seats do not heat or cool.
I assume there must be a Module or some additional wiring to be done.
Has any one else done this change out and if so what have I missed out?
Thanks
Post #146279 13th Oct 2012 7:26pm
I'v never looked under my seats but I assume they must be plumbed into the HEVAC system to get their heated or cooled air ? cant say for sure though. 2008 MY Supercharged
Post #146287 13th Oct 2012 8:13pm
Googsy
sorry to deviate ...out of interest what colour is interior and are you selling old seats? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #146290 13th Oct 2012 8:22pm
Trantorman
its all electrical and all of the connections are the same, the later seats have a cooling fan in them + the Heating elements, I assume there should be a Further ECU and a link piece of Electrical wiring, thats the bit I am unsure off.
Post #146292 13th Oct 2012 8:23pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #146293 13th Oct 2012 8:23pm
Heated and cooled seats in a FFRR...whatever is the world coming to. Sounds like you should be driving an A8 instead Whistle
Post #146294 13th Oct 2012 8:24pm
Trantorman
I fitted a full black interior and I have already sold off the old one.
Post #146295 13th Oct 2012 8:24pm
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
There is a further Motorola control unit for the climate seats positioned under the removable plastic panel under the drivers seat, maybe this is the piece you need plus the associated wiring to complete your retro fit project? MY2007 S/C - Stornoway / Jet
Post #146354 14th Oct 2012 3:16pm
Trantorman
I have looked under both seats and there is only the Body Conrol Module.
Land Rover lists HLV 500080 Module seat Heater Control but I can not find where it lives!
Post #146370 14th Oct 2012 6:52pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Can you get to these modules without taking the seats out? I need to have a poke about at mine but I'm not sure I want to unbolt the seats. If not, how hard is it to take a seat out?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #146374 14th Oct 2012 7:27pm
Trantorman
Taking the seats out is 4 x Allen Bolts slide it back take out the front bolts, slide it forward take out the back bolts then Diconnect the Electrical plugs, all very straight forward
Post #146375 14th Oct 2012 7:33pm
Jpickie
That would be correct on a vehicle that was not originally fitted with climate seats like yours or are you talking about the donor vehicle you got the seats from? If so maybe the position changed between model years as it is definitely under the drivers seat on mine. Anyway there is one on eBay at the moment, good for the pics to see what you are looking for if nothing else.http://www.ebay.co.uk/itm/2008-RANGE-ROVER...1165655212 MY2007 S/C - Stornoway / Jet
Post #146389 14th Oct 2012 10:38pm
TheAllSeeingPie
Hmm for £10 I might take a punt and see if it fixes my sporadic seat issues. Maybe after I have pulled the seats out though, which could take me longer than the auction to get round to ...
Post #146396 15th Oct 2012 7:27am
TheAllSeeingPie
Ok, I managed to get the seat out and found some rice crispies, a biro and some boiled sweets on the ECU. Tested the seat out with the ECU in my hand and it appears to "click" and turn off when it does the drivers seat. Doesn't do the same for the passenger seat. Might have to try a new one after all ...
Post #146443 15th Oct 2012 11:24am
Trantorman
I have ordered the ECU and 2 additional wiring looms that show on the parts lists for heated and cooled so i can see what happens does the ecu sit under the seat or under the centre console?
Any ideas or photos would be usefull.
Thanks
Post #146499 15th Oct 2012 5:15pm
