![]() | Home > Technical (L322) > which diagnostic? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 ![]() ![]() ![]() |
That'll be the IID tool then! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 ![]() ![]() ![]() |
I have RSW All Comms, that will do it.
dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20 ![]() ![]() ![]() |
all comms is looking good to be honest and not badly priced either. I may just be getting in touch with mr storey wilson
Hi dogswick,
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Getting the pixels fixed is relatively easy - getting the instrument cluster out is a 40 min job (first time - faster after!) and there are a number of people around who can fix (although the one I used is in Stirling, so not the closest to you...) l:OolΞΞΞΞΞΞloO:l 2002 4.4 Vogue Java Black |
Thanks. The pixel issue is the last "defect" to fix. There is a chap in Southampton that is recommended on here, but its a good run and I don't fancy taking the instrument cluster out and posting it off.
As far as I can remember, you were within three torx scews! |
Thanks for the advice people.
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
Pm piecost76. He has an hawkeye and has told me you can calibrate the suspension with it. |
Hi dogswick,
Not unless something has been changed very recently... ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Depends what is meant by "callibration"
Calibration is calibrating the corner heights on the EAS - for instance after replacing a height sensor.
Probably the wrong guy to ask but what do they mean by "Program System" then?
