Home > Technical (L322) > which diagnostic? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
That'll be the IID tool then! Got - 2017 SDV8 Autobiography in Loire Blue
7th Oct 2012 1:29pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
I have RSW All Comms, that will do it.
7th Oct 2012 2:34pm |
dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20 |
all comms is looking good to be honest and not badly priced either. I may just be getting in touch with mr storey wilson
7th Oct 2012 7:00pm |
Hi dogswick,
7th Oct 2012 9:40pm |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
Getting the pixels fixed is relatively easy - getting the instrument cluster out is a 40 min job (first time - faster after!) and there are a number of people around who can fix (although the one I used is in Stirling, so not the closest to you...) l:OolΞΞΞΞΞΞloO:l 2002 4.4 Vogue Java Black |
8th Oct 2012 10:40am |
Thanks. The pixel issue is the last "defect" to fix. There is a chap in Southampton that is recommended on here, but its a good run and I don't fancy taking the instrument cluster out and posting it off.
8th Oct 2012 1:16pm |
As far as I can remember, you were within three torx scews!
8th Oct 2012 2:18pm |
Thanks for the advice people.
13th Oct 2012 4:31pm |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 |
Pm piecost76. He has an hawkeye and has told me you can calibrate the suspension with it. |
13th Oct 2012 5:34pm |
Hi dogswick,
16th Oct 2012 12:44pm |
Not unless something has been changed very recently... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
16th Oct 2012 12:45pm |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Depends what is meant by "callibration"
16th Oct 2012 12:56pm |
Calibration is calibrating the corner heights on the EAS - for instance after replacing a height sensor.
16th Oct 2012 1:24pm |
Probably the wrong guy to ask but what do they mean by "Program System" then?
16th Oct 2012 1:36pm |
