Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 16 of 49 <123 ... 151617 ... 474849>
mzplcg
As an aside then, per my question about resetting gearbox adaptives, is this a feature which can be added in a future release please?
Thanks. Dom.
Post #144222 2nd Oct 2012 12:11pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
Gents regarding my post about the IIDtool not being able to read engine fault codes, bent pin 7 slightly and it has worked. Thank you.
Although im looking for advice on the faults it has appeared with they read as
412-o2 sensor circuit upstream sensor
405-o2 sensor heater circuit bank2 upstream fault
40D-o2 sensor heater circuit bank1 upstream fault
renewed all upstream sensors, maf plugs,pcv valve and hoses.
engine idles rough when engine management light is on, very poor mpg etc.
Please read topic 4.4v8 Oxygen sensors / Engine management light
http://www.fullfatrr.com/forum/topic12505.html
Any help appreciated, Fraser
Post #144891 5th Oct 2012 6:18pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Turned on 'nav on the move', however doesn't seem to work... any ideas?
Thanks.
Post #145247 8th Oct 2012 1:05am
stryke , read back through this thread and you'll find that i'm in the same situation..its something to do with the wrong nav firmware. ... - .- -.
Post #145251 8th Oct 2012 7:35am
Stryke
Will do stan. Thanks.
Post #145301 8th Oct 2012 11:30am
SteveMFr
Site Sponsor
It depends on which SW version you have in the nav computer and the country code setting. Some combinations allow nav on the move, some don't.
We do plan to look back into this as well. Possibly we can find a work-around...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #145309 8th Oct 2012 12:34pm
Budgie
I've just had a play with the DRL settings on my 2003 4.4 and I have a question;
If I set it to use the Main Beam then only the main beam headlights come on.
If I set it to use the Dip Beam then all the lights come on, ie dashboard, side, dip, rears & number plate.
Is this normal as I would have expected just the front dip beam to be used?
I've set it to use the main beam at 40% for now as I don't want all the lights on. Wink
BTW, the ability to stop the "bong" for the key in the ignition is a God send! Thumbs Up
Post #145325 8th Oct 2012 2:07pm
i think the dip beam setting would be accessing the Scandinavian part of the drl which does have the rears on as well...
agree re the ignition bong.. Thumbs Up ... - .- -.
Post #145329 8th Oct 2012 2:20pm
Budgie
That would make sense, I though it would be like my TD5 Disco where you could access the Canadian DRL which just have the dipped headlights on.
Not to worry, I'll see how it goes with the mains on at 40%. Wink
Post #145334 8th Oct 2012 2:40pm
i believe if the canadian setting isnt programmed into the LCM then it cant be accessed by the IIDTool... ... - .- -.
Post #145335 8th Oct 2012 2:49pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Had a look through most of this thread, but didn't see what I was looking for, but I appologise if this has been covered before.
After replacing the front air springs, and getting everything going again, all faults cleared, I went through each ECU and checked for any other fault codes that were still lurking. I found 3 - nothing major, just an EGR fault, a low voltage in the Transfer case and something in the Anti theft.
I thought I'd clear all the errors again, but when I did, it cleared 18 faults, not the 3 I could see. What else is the tool looking at and clearing that I can't see when I read the faults?
Cheers - Gav
Post #145716 10th Oct 2012 3:22am
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
I think the number it shows is the number of ECU's it is accessing to look and then clear the faults if there is one.
I presume you did the 'clear all faults' and not individual ECU.
This is what appears to happen on mine even though I only have a small number of recurring faults (inc low voltage at transfer box!) but it counts up to 20 odd which I always presumed was it looking in each ECU for the faults.
I never thought that number was the number of faults cleared, but I am sure if I am wrong someone will say.
G
Post #145728 10th Oct 2012 7:33am
KARMANN
Yeah you both are correct. It's counting the number of ecus it's accessing, not the number of faults cleared.
Fraser
Post #145738 10th Oct 2012 8:18am
The Brains Trust
Ah - thanks guys. Very Happy Thumbs Up
Post #145765 10th Oct 2012 9:49am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
PM sent Gav
Gary
Post #145810 10th Oct 2012 2:13pm
