Home > Technical (L322) > HELP td6 on 52 plate
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
hi gang, car just been recoverd by the aa. car wont start but cranks ,put hawk eye on only fault showing is (FD15) imobilisation (ews)
rest all clear turn over the same fault comes up .
now battery flat and now battery charger so need to get one .
any ideas( have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #145071 6th Oct 2012 7:46pm
Erm buy a battery charger tomorrow, or more likely, you may well need a new battery if it's never been replaced before. Got - 2017 SDV8 Autobiography in Loire Blue
Post #145072 6th Oct 2012 7:48pm
trainmanone
going to get one mon as in work tommorow have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #145073 6th Oct 2012 7:51pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
May just be your secondary diesel pump??? RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #145112 6th Oct 2012 9:34pm
Have a read at this thread
Post #145115 6th Oct 2012 9:46pm
trainmanone
yes read that but aa say thje pump is running,plus hawkeye is only showing immobiliser fault as showen in 1st post .
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #145125 6th Oct 2012 10:01pm
trainmanone
update ...... my son has admitted he was "playing with hawkeye and says he went on to securety setings ang "might have " presed sincronise,this woul explanme why it turns over and wont start, Now for the big question can i sort this with hawk eye or not.
i hate kids who think they know every thing hes 17 and a Censored Censored
can any one advise pls bat on charge now so wont be able to do anything till mon pm.
Post #145232 7th Oct 2012 10:18pm
ask your son to sort it pete... Thumbs Up ... - .- -.
Post #145252 8th Oct 2012 8:39am
If Hawkeye has the capability to disable it then it must be able to do the opposite. Drop Hawkeye an email and see if they can help
Post #145257 8th Oct 2012 8:51am
mjdronfield
Do you not just have to finish the synchronising process now, and you will be OK ?
Assume it synching the key with the car..........until its completed, the car won't start......
sort of "go with the flow" if you see what I mean.........
Could be wrong...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #145264 8th Oct 2012 9:27am
trainmanone
just put a fully charged battery on and still the same fault
any one know of a mobile mechanic with the correct sofwhere to help me please im in stockport just off j 1 m60
Post #145342 8th Oct 2012 4:15pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Just try the procedure to sync the keys.
In the wiki I think.
Post #145344 8th Oct 2012 4:18pm
mjdronfield
From RAVE
Hope it helps......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #145346 8th Oct 2012 4:36pm
trainmanone
just tried that mjdronfield still no joy Big Cry
im going to kill my son for this .
begining to wish i had keeped the omega now
Post #145350 8th Oct 2012 5:00pm
mjdronfield
Its not the cars fault............ Smile
Have you only got the 1 key ?
Assume any others don't work either - you would obviously have tried that ages ago..........
The dealers will prob charge you an arm to collect the car and then a leg to code the keys up.
Do you not have a friendly independent specialist who can have a chat to you over the phone about what you can try ?
I wonder if taking the battery off again will reset it, or at least get it in a position where you can synch again ?
Just quessing really now..........
Sorry - just read the instructions above, looks like it cancels any existing keys as soon as you start this procedure, so any other keys would prob not work anyway.
Only thing I can think of is keep trying the procedure.....?
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #145352 8th Oct 2012 5:24pm
