![]() | Home > Technical (L322) > HELP td6 on 52 plate |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
hi gang, car just been recoverd by the aa. car wont start but cranks ,put hawk eye on only fault showing is (FD15) imobilisation (ews)
going to get one mon as in work tommorow have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
May just be your secondary diesel pump??? RANGE ROVER 04 TD6
Have a read at this thread |
yes read that but aa say thje pump is running,plus hawkeye is only showing immobiliser fault as showen in 1st post .
update ...... my son has admitted he was "playing with hawkeye and says he went on to securety setings ang "might have " presed sincronise,this woul explanme why it turns over and wont start, Now for the big question can i sort this with hawk eye or not.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
ask your son to sort it pete... |
If Hawkeye has the capability to disable it then it must be able to do the opposite. Drop Hawkeye an email and see if they can help |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Do you not just have to finish the synchronising process now, and you will be OK ?
just put a fully charged battery on and still the same fault
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Just try the procedure to sync the keys.
From RAVE
Hope it helps......... 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
just tried that mjdronfield still no joy |
Its not the cars fault............ |
