Home > General > 2009/2010 europe dvd satnav disc
Page 3 of 4 <1234>
daveo
hi dubbs, the prospective view is on the upgrade disc not the map, do you know what version you are running. V8 facelift Range Rover Autobiography 22" wheels.
Post #14330 4th Mar 2010 8:29pm
RREIRE
Ireland 2007 Range Rover Vogue SE TDV8 Java Black
I had a look at my disc. it is the original one. How do I get a new disc? Are they very expensive to buy from dealer? I am going to Edinburgh next week. So I hope to get one when I am over.
Post #14339 5th Mar 2010 12:00am
daveo
Hi rreire, i can do you one if you pm me your address, it will be v3.2 with speed cameras and prospective view and the range rover logo splash screen.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #14342 5th Mar 2010 8:08am
RREIRE
daveo
Thanks for that. Did you get my pm? I have not sent one before. Just want to know if I sent it correctly.
Post #14434 6th Mar 2010 8:50pm
RREIRE
daveo
Post #14435 6th Mar 2010 8:51pm
daveo
i mate, done you a upgrade disc and a map with speed cameras, will post out to you monday, just messing around with new splash screens and poi's...pm me your email and i wil send loading instructions
Post #14437 6th Mar 2010 10:32pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Silly question time - I just upgraded to the 2009-10 DVD (Mk 4) but couldn't see any mention of speed cameras under the POI section.
When the DVD was first inserted a green progress bar was displayed and it had text about a software update.
Are the speed camera warnings under a different section or a different POI download ?
Post #14495 8th Mar 2010 9:08am
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
..thats why I said, you need to have a modified firmware CD. At the DVD are only the coordinates of the speed trap positions. XJC, RRV8, Series1 86 and 107% of real pleasure
Post #14504 8th Mar 2010 12:44pm
daveo
hi, only the modified maps will hold speed cameras poi, if its an original disc it wont have them. V8 facelift Range Rover Autobiography 22" wheels.
Post #14512 8th Mar 2010 3:53pm
Can you modify a 2009/10 Disc used in my 2007 TDV8 to include speed Cameras? If so how!
Many thanks
Gaz
Post #14515 8th Mar 2010 4:11pm
VaguelyVogue
Ah - so it's not like TomTom (for example) where each POI is stored in a different file (which I could add to my backup copy of the LR disc) ?
Post #14516 8th Mar 2010 4:20pm
daveo
hi, yes it is the same as a tom tom, but you cant add to it when you want, you have to add to the map file and then write a new dvd,but its a bit more complicated...navtwek is the programe you will need. V8 facelift Range Rover Autobiography 22" wheels.
Post #14517 8th Mar 2010 5:33pm
daveo
hi gazellio,,
i could do you the 2009/10 map with speed cameras but you will need to have updated you dvd firmware with the latest v3.2 update.. but again it has to be a modified one and not standard.
the modded upgrade software tells the nav unit to point out the camera poi's that have been added to the map V8 facelift Range Rover Autobiography 22" wheels.
Post #14518 8th Mar 2010 5:39pm
SAppie
Info mismatch
Guys, unless i'm mistaken, from around the facelifted 2006 FFRR model onwards, they changed the SAT NAV to one manufactured by Denso that is the touch screen type. The system that is being discussed above relates to the older non touch screen type (BMW).
The 2 systems are very different and are not compatible.
I'm running the new 2009/2010 European maps, and the system software was upgraded to the latest version which is reported as follows:
SW ver 1070 06/26/07
Map ver EU V03.09.03
As far as i'm aware there is no software that allows us to add POI's as yet.
hope that helps, and please let me know if this is utter crap Smile
Post #14530 8th Mar 2010 7:45pm
dan_uk_1984
I've noticed TMC PLUS now shows in my menu after updating, it seems this is an enhanced TMC version currently being rolled out in Austria. Anyone know anything more about it? Like will it ever make it to the UK?
Dan
Post #14963 16th Mar 2010 9:00pm
Page 3 of 4 <1234>
