Home > Technical (L322) > Vibration while stationary in drive |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
I have a vibration issue when I pull up at the lights etc when in drive
6th Oct 2012 2:08pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I thought the vibration was "normal", and why Land Rover didn't initially fit 19" wheels to the Td6.
6th Oct 2012 3:18pm |
Thanks MJ
6th Oct 2012 3:44pm |
Here's one question is there any fluid in a torque converter???? RANGE ROVER 04 TD6
6th Oct 2012 4:10pm |
What made you decide to add the two-stroke oil in the first place ? 2011 Range Rover Vogue SE 4.4 TDV8
6th Oct 2012 5:02pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
I'd come across this in diesel engines before but had never got round to it.
6th Oct 2012 5:15pm |
Fair enough. I imagined all sorts of oil type exhaust smoke, but if its onlt 1 to 200, it seems pretty minimal.
6th Oct 2012 5:21pm |
Sounds about right with the two stroke but think ill leave that until I've sorted the underlying problem first
6th Oct 2012 7:34pm |
Was the weight of the vehicle on the gearbox pawl, this would put a strain on the box and cause the symptoms |
6th Oct 2012 7:42pm |
The fluid in the TC is shared with the auto gearbox its actually a version of ATF fluid. Might be worth changing the fluid as a starter the proceedure is detailed in the Wiki above under "td6 auto box oil change".i |
6th Oct 2012 7:44pm |
Yes the weight was on the gearbox , not sure what part of the gear box is a pawl. I thought that was a sort of ratchet system
6th Oct 2012 7:52pm |
Texamatic 7045 e is what I used
6th Oct 2012 7:54pm |
Not good practice to let the gearbox take the weight of the vehicle on an incline as it is possible to damage the parking pawl.
6th Oct 2012 8:01pm |
+1 for the above, if you don't do it already......... 2011 Range Rover Vogue SE 4.4 TDV8
6th Oct 2012 8:14pm |
