![]() | Home > Technical (L322) > Vibration while stationary in drive |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
I have a vibration issue when I pull up at the lights etc when in drive
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I thought the vibration was "normal", and why Land Rover didn't initially fit 19" wheels to the Td6.
Thanks MJ
Here's one question is there any fluid in a torque converter???? RANGE ROVER 04 TD6
What made you decide to add the two-stroke oil in the first place ? 2011 Range Rover Vogue SE 4.4 TDV8
I'd come across this in diesel engines before but had never got round to it.
Fair enough. I imagined all sorts of oil type exhaust smoke, but if its onlt 1 to 200, it seems pretty minimal.
Sounds about right with the two stroke but think ill leave that until I've sorted the underlying problem first
Was the weight of the vehicle on the gearbox pawl, this would put a strain on the box and cause the symptoms |
The fluid in the TC is shared with the auto gearbox its actually a version of ATF fluid. Might be worth changing the fluid as a starter the proceedure is detailed in the Wiki above under "td6 auto box oil change".i |
Yes the weight was on the gearbox , not sure what part of the gear box is a pawl. I thought that was a sort of ratchet system
Texamatic 7045 e is what I used
Not good practice to let the gearbox take the weight of the vehicle on an incline as it is possible to damage the parking pawl.
+1 for the above, if you don't do it already......... 2011 Range Rover Vogue SE 4.4 TDV8
