Home > Technical (L322) > Help please Cant Turn Key in ignition unless battery HR |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Anyone know why Vaseline seems to be preferable to copper slip for battery terminals? |
2nd Oct 2012 3:21pm |
Copper grease will eventually dry out through time, Vaseline is waterproof and a good conductor.
2nd Oct 2012 4:17pm |
44ark Member Since: 01 Apr 2011 Location: faringdon oxon Posts: 58 |
well have removed all terminals gave them a rub with emerory clothe and lubed up with a bit of vas also tightened everything up really tight so time will tell.
3rd Oct 2012 8:03am |
That battery is way too small |
3rd Oct 2012 8:06am |
so could this battery be the root to my problems as i have had on and off electrical issues where i have had to disconnect the battery and HR since i have owned the car and it has always had this battery on it Supercharged LPG!! |
3rd Oct 2012 8:15am |
That size battery is roughly what my daughter has in her Audi A6, so yes it could well be the cause of your problems |
3rd Oct 2012 8:17am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
yes... ... - .- -.
3rd Oct 2012 8:18am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
Although the battery is too small in terms of capacity for your car and should be changed for the correct one, going back to your original post I doubt the existing battery is causing all your problems, after all you say that disconnecting and reconnecting brought the car back to life and allowed you to start it.
3rd Oct 2012 8:29am |
The size of the battery still does not explain the working one minute and not the next unfortunately. I do agree it is way too small, I have a 110 Ah in my S/C.
3rd Oct 2012 8:30am |
yeah i checked the earth point in the bulkhead and made sure it was nice and tight with no signs of corrosion will wait and see if happens again then if it does will change the battery out then if it still happens auto electrician may need to be called.
3rd Oct 2012 8:38am |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Bad connection at power source
3rd Oct 2012 3:57pm |
Another not very likely scenario is a break in one of the battery poles although that should be aggravated by driving on bumpy surfaces.
3rd Oct 2012 4:05pm |
