![]() | Home > Technical (L322) > Help please Cant Turn Key in ignition unless battery HR |
44ark Member Since: 01 Apr 2011 Location: faringdon oxon Posts: 58 ![]() ![]() |
Hi guys
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
bad earth or most likely it is the battery.....disconnecting and reconnecting probably gives the car a 'boost' of power letting you start it..if the battery is more than 3 years old'ish then its time to replace , especially now winter is coming.... ... - .- -.
i was told battery was replaced when i brought the car about 18 months ago just spoke to the wife and she said that no electrics work not even the interior lights when it happens. So could be dodgy connection or as you say battery.
Could also be the alternator dying, it could be draining the battery. Better get it to a good auto electrician. Also because you have been "draining" the battery a bit, it is getting damaged. Could also be a bad battery that would never have made it 3 years. Sometimes battery cells just die. MY 2010 5.0 SC Galway green and sand interior!!
will check all the connections tonight and have just got a price for £120 for a new battery fitted so will take it over there and get them to test the old battery before replacing it aswell. Supercharged LPG!! |
Click here for battery info from Eurocarparts for £99.86
Key in ignition, everything normal, switch to ignition, still normal, try to start, completely dead = bad connection on one of the main battery cables either + or ground.
cheers have spoke to battery place and can get a good battery for £120 fitted apparently the eurocar parts one is not strong enough as the CCA is not high enough or something.
Biggest load of bullsh1t I've heard yet, it's the biggest most powerful battery you can fit in a FFRR Proceed with Caution ![]() |
^^^^^^ +1 what john said.... ... - .- -.
+2
![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
thats what im struggling with alot of people say its the battery for everything but i dont understand if it is the battery than how would it come back to life and start the car fine??? Supercharged LPG!! |
might not be the battery , but the connections.. |
is it just the battery terminals to test or our there anymore anywhere that i need to look at? Supercharged LPG!! |
