Home > Technical (L322) > Where is the fuse box
lesmcm
South Africa 2003 Range Rover HSE Td6 Atacama Sand
I have 2003 TD6 the gearbox ecu has 2 Red blue cables feeding, it which according to the diagram should have 12v on them via a 30 amp fuse from the battery. The fuse is in the engine compartment fuse box. Can anybody tell me where this box is or where the fuse as I have no voltage at the ecu
Post #144124 2nd Oct 2012 7:58am
ebajema
There is a big black box on (your) drivers side under the hood. It is just behind the headlight next to the wheel arch. It has a big cover on top that is screwed down with torx screws. In their you have the gear box ECU, transfer box ECU and a bunch of fuses, relays and connectors. It is very easy to get to and work on.
Good luck and keep us posted please. MY 2010 5.0 SC Galway green and sand interior!!
Post #144126 2nd Oct 2012 8:06am
lesmcm
Thanks
I found it shortly after sending the message.
Post #144237 2nd Oct 2012 12:44pm
