Home > Maintenance & Mods (L322) > Note to Self: Check Tyre Pressures Regularly
Not checked 'em for a few weeks:
Fronts: 20 (!) 30
Rears: 30 30
All pumped up now F 33 R 36 Smile .
Post #142492 22nd Sep 2012 11:43am
Worth noting that 33/36 is full pressure for a loaded car.
If your driving solo during winter 30/33 is good and comfy unless high speed motorway.
Post #142511 22nd Sep 2012 2:56pm
I was waiting for that !!
From the handbook for my model:
Normal operating conditions: Front 33 Rear 36
Vehicle loaded to maximum gross vehicle weight: Front 36 Rear 44
Razz Razz Razz .
Post #142512 22nd Sep 2012 3:09pm
Yes but they assume two peeps and luggage....... Whistle
Local solo no luggage and its a bit hard.
Post #142513 22nd Sep 2012 3:11pm
is that with just a bit of fuel or a full tank. Mr. Green ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #142515 22nd Sep 2012 3:43pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
How "high-speed" are we talking here? I need to check my tyre pressures soon so was looking for recommendations for comfort.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #142528 22nd Sep 2012 6:03pm
Pitsnow
For those of us which work in current pressure measurement units, below a conversion table from the old to the new. Personally, I use 2.3 bar for the front and 2.5 bar for the back.
20 psi = 1.37 bar
25 psi = 1.72 bar
30 psi = 2.06 bar
33 psi = 2.27 bar
36 psi = 2.48 bar
40 psi = 2.75 bar
44 psi = 3.03 bar
Here is what the Michelin man (source: http://www.michelin.co.uk/tyres/learn-shar...-pressure) has to say for the tyre pressure:
By keeping your tyres at their correct pressure, you’ll reduce your running costs.
Under inflated tyres are prone to overheating use more fuel and wear out more quickly.
Likewise, over inflation can reduce tyre life, reduce grip and cause steering problems.
WEAR. A tyre which is 20% under- inflated can give 20% less mileage. That means a loss of 5,000 miles (8,000 km) on a potential mileage of 25,000 miles (40,000 km).
FUEL CONSUMPTION AND CO2 EMISSIONS. Low tyre pressure increases both fuel consumption and CO2 emissions.
Follow the advice of the vehicle or tyre manufacturer, particularly with regards to the conditions of use (loads/speeds etc.)
• Check pressures when the tyres are cold (tyres which have not been used in the last 2 hours or have covered less than 2 miles (3 km) at low speed).
• If tyres are hot when they are checked, add 4 to 5 psi (0.3 bar) to the pressure recommended by the vehicle manufacturer. Re-check the pressures when the tyres are cold.
• Never deflate a hot tyre.
• Even if tyres are inflated with nitrogen, the pressures and overall tyre condition must still be checked frequently
With 2 bar or 30 psi at front and 2.27 bar or33 psi back you are underinflating your tyres by 10%.!
Post #142554 23rd Sep 2012 3:56am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
My front tyres will go from 2.3 bar to ~1.5 bar in less than a month, recently checked the right tyre and it had dropped to 1 bar, left tyre was 1.3 Shocked
I guess losing almost 1 bar in just a few weeks isn't normal?
Post #142563 23rd Sep 2012 10:34am
klf400
Correct tyre pressure will also depend on the size of the tyre Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #143430 28th Sep 2012 6:38am
My point was that as a solo driver you can get more comfort and winter grip with slightly lower pressure than the recommended. Car manufacturer's build in a "Safety Margin" to protect themselves against liability.
I like 30/33 with winter tyres for local winter use but that just my choice and is only 10% below Manufacturer's Recommended just in case limits that assume two people and a little luggage.
Please do not take this as advice though (protecting myself Whistle )
Last edited by Gazellio @ Prestige Cars on 28th Sep 2012 8:19am. Edited 1 time in total
Post #143435 28th Sep 2012 8:13am
i agree with gary but dont reduce the pressures any more than what gary has stated and remember to increase if going on a high speed ,long journey .. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #143436 28th Sep 2012 8:14am
I keep mine at 35 front and 38 rear. Makes it a bit more economical and the fronts only end up getting scrubbed anyway from corners so the wear is almost even at that end.
Boot it out of a corner though and the DSC kicks in Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #143449 28th Sep 2012 9:24am
Pitsnow
I dont agree with Gary Wink but each to their own as they say.
Please keep in mind that the pressure will drop even further if the temperature goes down.
How many of us go and check their tire pressure on a cold morning before they set off?
If your pressure is 30/33 to sart with and the temperature drops 10 C lower, I guesss (sure there is some tables hidden by google somewhere) you are talking tire pressure of 24/27 on a car that is 2.7 tonnes.
Post #143505 28th Sep 2012 12:29pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Surely once you start driving the tyre temperature will go up fairly rapidly? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #143506 28th Sep 2012 12:33pm
it wont drop 6 psi... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #143507 28th Sep 2012 12:37pm
