![]() | Home > Maintenance & Mods (L322) > Note to Self: Check Tyre Pressures Regularly |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Not checked 'em for a few weeks:
Worth noting that 33/36 is full pressure for a loaded car.
I was waiting for that !!
Yes but they assume two peeps and luggage....... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35658 ![]() ![]() |
is that with just a bit of fuel or a full tank. |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
How "high-speed" are we talking here? I need to check my tyre pressures soon so was looking for recommendations for comfort. ![]() 07 Supercharged - Still breaking her in! Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html 18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html |
Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183 ![]() ![]() ![]() |
For those of us which work in current pressure measurement units, below a conversion table from the old to the new. Personally, I use 2.3 bar for the front and 2.5 bar for the back.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
Correct tyre pressure will also depend on the size of the tyre |
My point was that as a solo driver you can get more comfort and winter grip with slightly lower pressure than the recommended. Car manufacturer's build in a "Safety Margin" to protect themselves against liability.
i agree with gary but dont reduce the pressures any more than what gary has stated and remember to increase if going on a high speed ,long journey .. ... - .- -.
I keep mine at 35 front and 38 rear. Makes it a bit more economical and the fronts only end up getting scrubbed anyway from corners so the wear is almost even at that end.
I dont agree with Gary |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Surely once you start driving the tyre temperature will go up fairly rapidly? African Bush Junkie ... in London! Stats: 2006 TD6 Vogue SE 1972-2015 DeRanged Rover 2001 P38 dHSE (SOLD) |
it wont drop 6 psi... ... - .- -.
