Home > Technical (L322) > Creaky suspension? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Over the last few days, the ffrr is making all kinds of creaky noises. It seems like it's coming from the front. Noticeable when slowing to a halt, steering whilst at a crawl and over speed bumps. It's a combination of creaking and knocking. Any ideas what it could be folks? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Feb 2010 6:16pm |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 |
Noddy, does it sound like she's running on leaf springs ?
9th Feb 2010 8:19pm |
Yeah, thats probably the best analogy - where are these front bushes located? I'm doing the front brakes this weekend so I'll do the lot together. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
10th Feb 2010 8:45am |
It might be the start of the front ball joints failing. They arent too expensive to replace, I had them done at an independant, I think £150 per side inc parts & labour should cover it. Mine failed within 6 months of each other, so it may be worth having both sides done if it does turn out to be this.
10th Feb 2010 9:12am |
Cheers for that Dan.
10th Feb 2010 9:21am |
I copied that info from rr.net....
10th Feb 2010 10:02am |
Its easily remedied mate- just undo the bolt slightly whilst its on the floor and re-tighten it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
12th Feb 2010 11:44am |
The strangest thing- it's not doing it now! Quiet as a mouse! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
15th Feb 2010 5:57pm |
Nothing mate- just stopped creaking! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
27th Feb 2010 6:51pm |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 |
Nine times out of ten the creaking from the rear suspension is caused by a failing bush in the upper wishbone (pictured and arrowed below). They're not expensive to buy - under £20 - but can be a pain to do at home if you don't have the correct insertion tool. I just remove the whole hub and press the bush in and out with a hydraulic press, but a dealer would do it in situ, so expect to be billed for about an hour's labour.
28th Feb 2010 6:09pm |
I've done similar jobs on trucks with a socket and a G clamp in the past! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
1st Mar 2010 12:02am |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
Nice info boys Sounds like the culprit.
1st Mar 2010 5:44am |
Well, just took the car for MOT and it failed - ball joints!
1st Mar 2010 10:16am |
Euro Car Parts wanted £50 a side plus vat for the arms, so I went to Island 4X4 - £35 each inc vat delivered 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
2nd Mar 2010 8:32am |
