![]() | Home > Technical (L322) > Creaky suspension? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Over the last few days, the ffrr is making all kinds of creaky noises. It seems like it's coming from the front. Noticeable when slowing to a halt, steering whilst at a crawl and over speed bumps. It's a combination of creaking and knocking. Any ideas what it could be folks? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 ![]() ![]() |
Noddy, does it sound like she's running on leaf springs ?
Yeah, thats probably the best analogy - where are these front bushes located? I'm doing the front brakes this weekend so I'll do the lot together. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
It might be the start of the front ball joints failing. They arent too expensive to replace, I had them done at an independant, I think £150 per side inc parts & labour should cover it. Mine failed within 6 months of each other, so it may be worth having both sides done if it does turn out to be this.
Cheers for that Dan.
I copied that info from rr.net....
Its easily remedied mate- just undo the bolt slightly whilst its on the floor and re-tighten it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
The strangest thing- it's not doing it now! Quiet as a mouse! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Nothing mate- just stopped creaking! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
Nine times out of ten the creaking from the rear suspension is caused by a failing bush in the upper wishbone (pictured and arrowed below). They're not expensive to buy - under £20 - but can be a pain to do at home if you don't have the correct insertion tool. I just remove the whole hub and press the bush in and out with a hydraulic press, but a dealer would do it in situ, so expect to be billed for about an hour's labour.
I've done similar jobs on trucks with a socket and a G clamp in the past! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
Nice info boys |
Well, just took the car for MOT and it failed - ball joints!
Euro Car Parts wanted £50 a side plus vat for the arms, so I went to Island 4X4 - £35 each inc vat delivered |
