Home > Technical (L322) > Aux heater
jay-p
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Aux heater
My 2002 4.4 v8 appears to have this option on the screen, I always thought these were only on diesels? How do they work?
Post #138891 1st Sep 2012 11:30am
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
As you have it on yours, you should be able to tell us; I now petrol versions could be equiped with this as an option.
Does it work?
If yes, does it run on petrol or diesel? RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #139865 6th Sep 2012 8:40pm
SteveMFr
Site Sponsor
If you do have it, it will run on petrol - they are avail in both versions.
Unless someone has been at your RR with a diagnostic tool capable of activating the park heat function (I assume this is what you mean) and had a play, you will likely have a FBH installed.
Set the timer and give it a go. If it sounds like a small jet is starting u der your RR, you have a FBH - congrats! Otherwise you'll get a fault code - and you'll need a diagnostic tool to have it read... :-p
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #139879 6th Sep 2012 9:57pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Mine is a 2005 petrol car and has fbh option which is brilliant in Winter.
Post #139904 6th Sep 2012 11:16pm
