![]() | Home > Technical (L322) > Tow bar question |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I take my towbar off when not in use but as its seized, I have to remove the nut & bolt and take the whole thing off out of the square hole.
Are there not two holes to put 2 bolts through?? This would create the up and down movement to a certain extent.
Slight play in mine.
Cut up an old credit card and wedge the right amount of pieces in the square receiver to stop the up and down movement that makes the clunk . 2008 MY Supercharged
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
As axle says, although I used a small piece of ali plate |
I did think about some shims actually. I'll get my mate to craft some for me. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
