Home > Technical (L322) > Tow bar question
Andy
Tow bar question
I take my towbar off when not in use but as its seized, I have to remove the nut & bolt and take the whole thing off out of the square hole.
When I refitted it yesterday, I noticed that there is movement up and down even though the nut & bolt are tightened to the max. I can't remember whether it was like this the last time it was on. There is no sideways movement. When I tow, I can hear it clunking.
Has anyone else got play in theirs? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #139381 4th Sep 2012 2:57pm
m3mjw
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
No play on mine. I had same issue with seized detachable part. Not sure if you have fixed that but i used a small file on the inside of the receiver and then gave the bearing on the towbar a good lube and worked like a dream L405 4.4 SDV8 Santorini/Black VSE
L332 4.4 tdv8 stornoway/Ivory VSE gone
L332 3.6 tdv8 black/sand vogue gone
Mk 7 vw golf r black/black(swmbo)
Mini Cooper s grey gone (swmbo)
BMW e60 m5 black/black gone
BMW e46 m3 silver/black gone
BMW e39 525i m sport blue/sand gone
Vw mk 4 golf gti blue/black gone
Post #139382 4th Sep 2012 3:03pm
Are there not two holes to put 2 bolts through?? This would create the up and down movement to a certain extent.
It wouldnt matter how tight the nut and bolt are anyway as the metal IIRC is pretty dam thick so wont have any clamping affect Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #139383 4th Sep 2012 3:03pm
Slight play in mine.
I hope you coated both parts with grease before assembly to stop them seizing in future. Very Happy
Post #139388 4th Sep 2012 3:16pm
Cut up an old credit card and wedge the right amount of pieces in the square receiver to stop the up and down movement that makes the clunk . 2008 MY Supercharged
Post #139393 4th Sep 2012 3:43pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
As axle says, although I used a small piece of ali plate Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #139408 4th Sep 2012 5:06pm
Andy
I did think about some shims actually. I'll get my mate to craft some for me. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #139455 4th Sep 2012 8:17pm
