Home > Technical (L322) > front speaker probs |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
hi all
17th Feb 2010 9:43pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
if you had one speaker not working or sounding bad it may be down to a broken wire but to have a few speakers not working i would check you multi plug on the amp, with a good wiring diagramit would show where your connectors are and you could meter out the wires to see if you have any breaks, V8 facelift Range Rover Autobiography 22" wheels.
17th Feb 2010 9:45pm |
scotty7 Member Since: 27 Oct 2009 Location: lanarkshire Posts: 65 |
ok folks,,
21st Feb 2010 7:09pm |
all that is the is model and make of speaker the one that burst had that on the back which i ignored (stupidly) and i replaced it with a HK speaker (same looking and bolt holes , sightly different wire contector had to mod slightly) but sound the same both sides
21st Feb 2010 7:16pm |
cheers andy i,ll bare that in mind,,
21st Feb 2010 7:47pm |
well folks,,
22nd Feb 2010 9:04pm |
update,,
24th Feb 2010 8:52pm |
yes, it sounds like one of your cables is grounding out..not sure the route they take... V8 facelift Range Rover Autobiography 22" wheels.
24th Feb 2010 10:46pm |
what do you meen by grounding out,,?
25th Feb 2010 8:33pm |
