Home > Technical (L322) > front speaker probs
scotty7
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
front speaker probs
wonder if anyone could help,,
the front mid range, tweeters and centre speaker on dash have no sound coming from them.
the bottom speakers on the front doors are very muted,
i think i may have a broken wire somewhere,,
so where should i be looking first?
is it a case of getting the door card off and having a good poke about
a point in the right direction or any help would be great
cheers scotty
Post #13321 17th Feb 2010 9:13pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
hi all
just changed my drivers lower speaker after the small centre disk (on the speaker) develped a split the up shot of this is it caused a feedback loop and created a realy loud buzzing from the main centre dash board speaker and very muffed sound from the rest of the speakers. (not good on the m25 Censored ) at some stage te whole sound went off as well. as the rip got bigger the noise did go and the speaker sounded very distorted.
all changed now got a new one from fleabay and fitted it no probs however it was very base orientated and not musch else (panic set in as i thought i had been ripped off ) i compared it with the other side door and it was exactly the same so i have put i down to being normal for my basic non sat nav system and when all the speakers are turned up the sound is good we;ll at least to my tone deafness
i would take the card off and do as you have sugested and check you conections Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #13325 17th Feb 2010 9:43pm
daveo
if you had one speaker not working or sounding bad it may be down to a broken wire but to have a few speakers not working i would check you multi plug on the amp, with a good wiring diagramit would show where your connectors are and you could meter out the wires to see if you have any breaks, V8 facelift Range Rover Autobiography 22" wheels.
Post #13326 17th Feb 2010 9:45pm
scotty7
ok folks,,
whipped the door cards off today and my problem was down to a burst mid range speaker on the passenger door.
so i need a speaker if anyone has one lying around,
on the back of the speaker it says
80RG003
XQM 000250
6911 605
made in uk
071-2-K-D
if someone could shed some light on what all that gumf means that would be great
thanks again
cheers scotty
Post #13500 21st Feb 2010 7:09pm
andyw
all that is the is model and make of speaker the one that burst had that on the back which i ignored (stupidly) and i replaced it with a HK speaker (same looking and bolt holes , sightly different wire contector had to mod slightly) Embarassed but sound the same both sides
got from ebay (25 quid)
Mr. Green 02 Range Rover HSE Zambezie silver 4.4
Post #13501 21st Feb 2010 7:16pm
scotty7
cheers andy i,ll bare that in mind,,
might give my local stealership a bell tomorrow and see how much they are,,
cant imagine they would be that bad
cheers scotty
Post #13507 21st Feb 2010 7:47pm
scotty7
well folks,,
phoned land rover stealer today for a new speaker,
£10.62 inc vat Whistle
bargain,,
would have probably of payed that for a second hand one off eblag.
cheers scotty Thumbs Up
Post #13624 22nd Feb 2010 9:04pm
scotty7
update,,
got the new speaker today, its the passenger side mid range.
there are two connections that go into it, when i plug the two of them in the other mid range, tweeters and centre speaker go off.
with only one of the connections in they all work but the new speaker sounds terrible,,
so i recon that i have a broken cable on one of the conection.
my question is, what route do the speaker cables run once they go through the door and into the bodywork?
i am going to change the cd changer at the weekend so will have that side of the dash stripped, am i going to see the speaker cables in there somewhere.
if anyone has any thought s that would be great
thanks again
cheers scotty
Post #13809 24th Feb 2010 8:52pm
daveo
yes, it sounds like one of your cables is grounding out..not sure the route they take... V8 facelift Range Rover Autobiography 22" wheels.
Post #13828 24th Feb 2010 10:46pm
scotty7
what do you meen by grounding out,,?
that its broken and touching the bodywork
cheers scotty
Post #13896 25th Feb 2010 8:33pm
